Welcome to the RAS Solution Forums HEC-RAS Help RAS Mapper – Map Polyline boundary not creating
  • #6496
    glyons
    I am having trouble creating a polyline in RAS Mapper for this data set.
    https://www.dropbox.com/s/6uf1bojtr8yhfwn/HEC-RAS.zip?dl=0
    In RAS Mapper I am right clicking on Results–>Manage Map Results.
    Under Plan 01 I select Add New Map.
    I am wanting to plot out an inundation boundary for the 02JUN2017 03:00:00 profile using polygon boundary at value option.
    For some reason, that I just cannot fathom, it will not create comes up map not created.
    I have also tried Depth–>poly at bdy
    and WSE–>poly at bdy.
    Also tried highlighting row and clicking on Compute/Update Stored Maps.
    Any help would be greatly appreciated.
    #10632
    Chad Ballard
    Not sure why it is not working tried create the map on my current project and it worked. You do need to highlight and “Compute/Update Stored Maps” but I was able to export as a shp or KMZ file.
    While I tried the process with your files I ran into the same problem that you are experiencing. Not sure why my files are working and yours are not but a workaround might be to export the Depth or WSE data into AcrGIS and use the “Raster Domain” tool.
    #10633
    glyons
    Return-Path:
    by sloti25t09 (Cyrus fastmail-fmjessie44025-14976-git-fastmail-14976) with LMTPA;
    Wed, 07 Jun 2017 18:20:59 -0400
    X-Cyrus-Session-Id: sloti25t09-2734463-1496874059-2-8616443771846969747
    X-Sieve: CMU Sieve 3.0
    X-Spam-known-sender: no
    X-Spam-score: 1.7
    X-Spam-hits: BAYES_00 -1.9, HTML_IMAGE_ONLY_16 1.092, HTML_MESSAGE 0.001,
    HTML_SHORT_LINK_IMG_2 0.001, RCVD_IN_BL_SPAMCOP_NET 2,
    RCVD_IN_DNSWL_NONE -0.0001, RCVD_IN_SORBS_SPAM 0.5, SPF_PASS -0.001,
    T_REMOTE_IMAGE 0.01, LANGUAGES en, BAYES_USED global, SA_VERSION 3.4.0
    X-Spam-source: IP=’23.83.223.214′, Host=’opossum.cherry.relay.mailchannels.net’,
    Country=’CA’, FromHeader=’au’, MailFrom=’au’
    X-Spam-charsets: plain=’utf-8′, html=’utf-8′
    by compute1.internal (LMTPProxy); Wed, 07 Jun 2017 18:20:59 -0400
    by mailmx.nyi.internal (Postfix) with ESMTP id 41CEDC81EF
    for ; Wed, 7 Jun 2017 18:20:59 -0400 (EDT)
    id 821509BB33B;
    dkim=none (no signatures found);
    dmarc=none (p=none) header.from=enciv.com.au;
    spf=pass [email protected] smtp.helo=opossum.cherry.relay.mailchannels.net
    Received-SPF: pass
    (enciv.com.au: Sender is authorized to use ‘[email protected]’ in ‘mfrom’ identity (mechanism ‘include:outbound-syd.hosting-service.net.au’ matched))
    identity=mailfrom;
    helo=opossum.cherry.relay.mailchannels.net;
    client-ip=23.83.223.214
    Received: from opossum.cherry.relay.mailchannels.net (opossum.cherry.relay.mailchannels.net [23.83.223.214])
    (using TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384 (256/256 bits))
    for ; Wed, 7 Jun 2017 18:20:54 -0400 (EDT)
    Received: from relay.mailchannels.net (localhost [127.0.0.1])
    by relay.mailchannels.net (Postfix) with ESMTP id 459A613605CC
    for ; Wed, 7 Jun 2017 22:20:49 +0000 (UTC)
    Received: from syd-s27e.hosting-service.net.au (unknown [103.18.109.132])
    by relay.mailchannels.net (Postfix) with ESMTPA id 0349513603A4
    for ; Wed, 7 Jun 2017 22:20:27 +0000 (UTC)
    Received: from syd-s27e.hosting-service.net.au (syd-s27e.hosting-service.net.au [103.18.108.15])
    (using TLSv1.2 with cipher DHE-RSA-AES256-GCM-SHA384)
    by 0.0.0.0:2500 (trex/5.7.30);
    Wed, 07 Jun 2017 22:20:48 +0000
    Received: from [49.197.199.73] (port=9795 helo=[192.168.43.139])
    by syd-s27e.hosting-service.net.au with esmtpsa (TLSv1.2:ECDHE-RSA-AES256-GCM-SHA384:256)
    (Exim 4.89)
    (envelope-from )
    id 1dIjJO-003oEy-0v
    for [email protected]; Thu, 08 Jun 2017 08:20:23 +1000
    To: “Chad Ballard [via HEC-RAS Help]”
    Subject: Re[2]: RAS Mapper – Map Polyline boundary not creating
    Date: Wed, 07 Jun 2017 22:20:20 +0000
    Message-Id:
    <[email protected]>
    Reply-To: “Grant Lyons”
    User-Agent: eM_Client/7.0.30068.0
    Mime-Version: 1.0
    boundary=”——=_MBBF24F43A-D1DA-4BFF-9D09-3A9FA3932789″
    X-Antivirus: Avast (VPS 170607-0, 07/06/2017), Outbound message
    X-Antivirus-Status: Clean
    X-OutGoing-Spam-Status: No, score=0.3
    X-AuthUser: [email protected]
    ——–=_MBBF24F43A-D1DA-4BFF-9D09-3A9FA3932789
    Content-Type: text/plain; format=flowed; charset=utf-8
    Thanks for the response Chad,
    Unfortunately I do not have ARCGIS so needed it imported into Autocad as
    a polyline.
    In the end I have just screen captured the image, aligned and traced
    over.
    Regards
    Grant Lyons
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
    Content-Type: text/html; charset=utf-8
    Unfort=
    unately I do not have ARCGIS so needed it imported into Au=
    tocad as a polyline.
    In the end I have ju=
    st screen captured the image, aligned and traced over.
    Regards
    Grant=C2=A0=C2=A0=C2=A0=C2=A0 Lyons
    <= /div>
    3D"" Virus-=
    free. http://www.avast.com
    ——–=_MBBF24F43A-D1DA-4BFF-9D09-3A9FA3932789–
    #10634
    You could have opened it in QGIS (which is free) and converted the depth grid to a polygon.
    #10635
    Lonnie A
    I’ve helped a colleague who was having the same issue. I couldn’t find any issue with the model but noticed that their terrain surface has a odd cell resolution of something like 6.562 so I resampled to a 5×5 and ran the model against that surface and it worked fine.
    Even if your surface doesn’t have a odd cell resolution you might try resampling it to see if that clears it up. Most likely it is terrain related I’m betting.
    #10636
    glyons
    Return-Path:
    by sloti25t09 (Cyrus fastmail-fmjessie44146-15178-git-fastmail-15178) with LMTPA;
    Tue, 13 Jun 2017 20:47:43 -0400
    X-Cyrus-Session-Id: sloti25t09-3460709-1497401263-2-12477731805771201475
    X-Spam-score: 1.1
    X-Spam-hits: BAYES_20 -0.001, HTML_IMAGE_ONLY_16 1.092, HTML_MESSAGE 0.001,
    HTML_SHORT_LINK_IMG_2 0.001, RCVD_IN_DNSWL_NONE -0.0001, SPF_PASS -0.001,
    X-Spam-source: IP=’23.83.223.166′, Host=’silver.cherry.relay.mailchannels.net’,
    Received: from mx1 ([10.202.2.200])
    by compute1.internal (LMTPProxy); Tue, 13 Jun 2017 20:47:43 -0400
    Received: from mx1.messagingengine.com (localhost [127.0.0.1])
    by mailmx.nyi.internal (Postfix) with ESMTP id C72962CF23
    for ; Tue, 13 Jun 2017 20:47:42 -0400 (EDT)
    by mx1.messagingengine.com (Authentication Milter) with ESMTP
    id BE10E982EA3;
    Authentication-Results: mx1.messagingengine.com;
    spf=pass [email protected] smtp.helo=silver.cherry.relay.mailchannels.net
    Received-SPF: pass
    receiver=mx1.messagingengine.com;
    identity=mailfrom;
    helo=silver.cherry.relay.mailchannels.net;
    client-ip=23.83.223.166
    Received: from silver.cherry.relay.mailchannels.net (silver.cherry.relay.mailchannels.net [23.83.223.166])
    by mx1.messagingengine.com (Postfix) with ESMTPS
    for ; Tue, 13 Jun 2017 20:47:39 -0400 (EDT)
    X-Sender-Id: hostingserviceptyltd|x-authuser|[email protected]
    by relay.mailchannels.net (Postfix) with ESMTP id 5A725136031A
    for ; Wed, 14 Jun 2017 00:47:34 +0000 (UTC)
    Received: from syd-s27e.hosting-service.net.au (localhost [127.0.0.1])
    by relay.mailchannels.net (Postfix) with ESMTPA id 295EB1360450
    for ; Wed, 14 Jun 2017 00:47:32 +0000 (UTC)
    Wed, 14 Jun 2017 00:47:33 +0000
    X-MC-Relay: Neutral
    X-MailChannels-SenderId: hostingserviceptyltd|x-authuser|[email protected]
    X-MailChannels-Auth-Id: hostingserviceptyltd
    X-Madly-Little: 049b83d636766354_1497401253750_964404554
    X-MC-Loop-Signature: 1497401253750:2487652222
    X-MC-Ingress-Time: 1497401253749
    Received: from [49.197.40.174] (port=24480 helo=[192.168.43.139])
    (Exim 4.89)
    (envelope-from )
    id 1dKwSs-003uiW-UI
    for [email protected]; Wed, 14 Jun 2017 10:47:27 +1000
    To: “Lonnie A [via HEC-RAS Help]”
    Date: Wed, 14 Jun 2017 00:47:17 +0000
    Message-Id:
    <[email protected]>
    Mime-Version: 1.0
    boundary=”——=_MB56CA81D6-21D8-4832-9EC5-C531916BF85C”
    X-Antivirus: Avast (VPS 170613-0, 13/06/2017), Outbound message
    ——–=_MB56CA81D6-21D8-4832-9EC5-C531916BF85C
    Thanks for the direction, I’ll see if I can figure out something that
    will work for me based on the info above
    Cheers
    Grant
    Thanks for the direction, I’ll see if I can fi=
    gure out something that will work for me based on the info above
    Cheers
    Gran=
    t
    3D"" Virus-=
    ——–=_MB56CA81D6-21D8-4832-9EC5-C531916BF85C–
    #10637
    Riley
    I am having the same issue. I resampled my terrain in GIS and still did not solve it. Exporting to a shapefile works in v4.1.0 but not v.5.0.3. When I exported in v.4.1.0, the WSE was somewhat pixelated. Also, using the Raster Domain tool created a very pixelated boundary as well. The shapefile in v4.1.0 was much better.
    Any fix to getting this to work in the new version? RAS mapper makes it too easy to map the floodplain but yet impossible to export that out to GIS.
    #10638
    I think I figured it out and now have it working.
    My 2D area boundary condition for the outlet had more that 2 nodes, once I altered it to only have two nodes I can now create a polyline and export to SHP file.
