Welcome to the RAS Solution › Forums › HEC-RAS Help › Ras Mapper – Manually add results
Hi, In Ras Mapper v2.0, I removed a layer from the Results with “Remove Layer” (not Remove layer and delete source files). Is there a way to add it back? thank you
Please enter an answer in digits:
