Welcome to the RAS Solution Forums HEC-RAS Help RAS Mapper issues with NLCD land cover data
  • #15019
    Golam Mohiuddin
    I was trying to create a new RAS classification layer using USGS NLCD 2016 dataset (.img format) in HEC-RAS 6.1 and 6.0 versions. Both gave me an error message as “Unknown Error: Bad Tiff Format”. Then I tried with v 5.0.7 and it worked. Anyone had the same issue with v 6.0/ 6.1? Not sure if that is a bug in the new version but any suggestions would be highly appreciated.
    Thank you,
    Golam
    #15028
    Luis Partida
    No, I have not had any issues with this, however you can create it in 5.0.7 and then use the “add existing land use RAS layer” and load it in the newer version
    #15384
    Mikey Johnson
    I too am having this issue. Is there any pre-processing that I can do to the NLCD data for 6.0.1 to recognize this format? Or should I step back to 5.0.7?
    • This reply was modified 4 years, 2 months ago by Mikey Johnson.
