Welcome to the RAS Solution Forums HEC-RAS Help RAS MAPPER – Interpolated Surfaces for Cross Section
  • This topic has 1 reply, 130 voices, and was last updated 6 years ago by Anonymous.
  • #7467
    Hi there,
    I have a problem about how does the HEC-RAS generate the interpolated surface. I have a channel has one interpolated surface from the first XS to the last one. However, this does not impact on the calculation, but it does impact on the mapping results.
    Screenshots show the interpolated surface and resulting maps are here https://drive.google.com/drive/folders/1qUMsDYmMyoTBmL-jkVd9Imz7Nn8wd6zi?usp=sharing
    Really appreciated if anyone have the similar situation and can provide solutions.
    CJ
    #12546
    TypicalEngineer
    In the geometry window where you are getting ready to interpolate lines there are two radio buttons mid window. Top is selected by default. You want the second one where it vaugely suggests to interpolate lines along or centered on the streamline. This option is needed for geo referenced models. See if that helps.
