Welcome to the RAS Solution › Forums › HEC-RAS Help › RAS Mapper: Index was out of range
- This topic has 2 replies, 2 voices, and was last updated 4 years, 5 months ago by Niels Dedring.
October 1, 2021 at 12:15 pm #15022Niels DedringParticipant
Hello everyone,
I am new to HEC-RAS so I apologize for my lack of knowledge. Overall I want to simulate a glacial lake outburst flood in the Himalayas, but I already struggling at the beginning. After I loaded my DEM (12,5 x 12,5) into RAS Mapper everything seems normal. But after I reopened it the Legend of the Terrain shows some crazy Values and when I try to open its properties the following Error pops up:Unhandled exception has occourred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediatley.
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: indexSee the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at RasMapperLib.SetSurfaceFill.DGV_Refresh(List1 values, List1 colors)
at RasMapperLib.SetSurfaceFill.Initializeform(ISurfaceFill sf, Dictionary`2 valueToStrVal)
at RasMapperLib.LayerProperties.cboStretch_SelectedIndexChanged(Object sender, EventArgs e)
at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
at System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value)
at RasMapperLib.LayerProperties..ctor(Layer layer, Form ownerForm)
at RasMapperLib.InterpolatedLayer.ShowPropertiesWindow(LayerPropertyTab layerTab)
at RasMapperLib.RASMapper.tvw_DoubleClick(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnDoubleClick(EventArgs e)
at System.Windows.Forms.TreeView.WndProc(Message& m)
at RasMapperLib.RASMapper.TreeViewDoubleClick.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4420.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
PipeServer
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/PipeServer.exe
System.Core
Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
Win32 Version: 4.8.4360.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Utility.Core
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/Utility.Core.DLL
RasMapperLib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/RasMapperLib.DLL
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Win32 Version: 4.8.4400.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
Geospatial.GDALAssist
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/Geospatial.GDALAssist.DLL
H5Assist
Assembly Version: 6.0.0.0
Win32 Version: 6.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/H5Assist.DLL
System.IO.Compression
Win32 Version: 4.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.dll
Hec.Dss
Assembly Version: 1.0.6.0
Win32 Version: 1.0.6.0
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/Hec.Dss.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data
Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Geospatial.Core
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/Geospatial.Core.DLL
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
ParticleTracking
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/ParticleTracking.DLL
OxyPlot.WindowsForms
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/OxyPlot.WindowsForms.DLL
OxyPlot
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/OxyPlot.DLL
System.Runtime
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.dll
TiffAssist
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/TiffAssist.DLL
System.Globalization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Globalization/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Globalization.dll
HDF.PInvoke
Assembly Version: 1.10.6.1
Win32 Version: 1.10.6.1
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/HDF.PInvoke.DLL
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
BitMiracle.LibTiff.NET
Assembly Version: 2.4.639.0
Win32 Version: 2.4.639.0
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/BitMiracle.LibTiff.NET.DLL
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
Geospatial.IO
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/Geospatial.IO.DLL
TiffBinaryReader
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/TiffBinaryReader.DLL
Geospatial.Rendering
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.1/Geospatial.Rendering.DLL
—————————————-************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.For example:
<configuration>
<system.windows.forms jitDebugging=”true” />
</configuration>When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I hope someone can help me with this Issue.
Many Thanks in advance,
NielsOctober 18, 2021 at 1:57 pm #15115Scott MillerParticipantI would guess you have set up a 2D model with a breach in an embankment. Correct? How well does flow pass from upstream to downstream boundary conditions without the breach? Check elevations of the breach with regard to the terrain. If the breach goes lower than the terrain, the problem may be there.
October 28, 2021 at 6:27 am #15125Niels DedringParticipantThanks for your response! I found my mistake and was much simpler… I haven’t changed the regional format of Windows from German to US, so HEC-RAS misinterpreted the , and .
