Mikayla. Do you keep the satellite image layer on? This generally slows down the rasmapper. Also, wouldn’t you be able to work with a smaller terrain, limited to the area you will simulate? This can be done, for example, in QGIS. I am not referring to decreasing terrain accuracy, but to cropping the image so that it is limited to just the region of interest. Another aspect: are you working on an SSD or a conventional hard disk? Consider working on an SSD; this greatly speeds up the processing and reading time of data by HEC-RAS.
Hope these starter tips help you.
