I have imported some shapefiles (watersheds) into the perimeters under the 2D flow areas and am trying to generate computation points. However, when I try to stop editing, I get an unexpected error and the edits are not saved. The error reads:
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Object reference not set to an instance of an object.
Could somebody please help me identify the problem?
