Welcome to the RAS Solution Forums HEC-RAS Help RAS Mapper – 1d/2d output options
  • This topic has 1 reply, 782 voices, and was last updated 9 years ago by Toby.
  • #6340
    Toby
    Greetings,
    I have a project with 1d channels and 2d floodplains and would like to make an animation with more functionality than RAS mapper offers. I have screen captured the outputs, and can try and video edit the results to what I want, but really would benefit from GIS functionality.
    I have played around with the Crayfish plugin for QGIS, but this only does the 2d mesh. http://www.lutraconsulting.co.uk/products/crayfish/ You can add the HEC RAS output*.p01.hdf file to Crayfish and have more options in QGIS, but no 1D support.
    Georas only supports 1d areas, right?
    Anyone have any tricks for 1d/2d animations? I want to add a better legend and labels, and polygons and points. I have added points and polygons in RAS mapper, but the results layer is always on top of the shapefile data.
    Thanks!
    #10361
    If you export out the raster results for each timestep in HEC-RAS you could load them into a raster catalog in ArcMap and create a animation. Another option may be to try the SMS 12.2 beta software as it is adding back in the HEC-RAS functionality.
