Welcome to the RAS Solution Forums HEC-RAS Help Question regarding tide stage hydrograph and effect of flooding
  • #6698
    ptdcaliguid
    Hi!
    I would just like to ask a question regarding tide boundary condition and effect of flooding 🙂
    So I have a tide elevation of water data and I run dam discharges and dam breach scenarios. I used a downstream boundary condition line and set a stage hydrograph data on it. So I run dam breach and flooding happens in downstream areas near the sea. Now will this be realistic? Wouldn’t the elevation at the downstream line change due to the flooding? Can that be modelled?
    #11036
    You can use a stage vs. time hydrograph that reflects the local tidal cycle at the downstream (ocean) end of the reach. As the tidal variation observation from gages usually depicts the WSEL for a large area, suggest that your downstream-most cross section be large enough that the velocity head is negligible. As usual this downstream boundary condition should be located far enough downstream of the area of interest that uncertainties in the values have no impact on the solution in study area. This for an ocean boundary a large cross section beyond the stream mouth. The upstream boundary condition in most situations should be a discharge hydrogaph. As the tidal cycle repeats continuously on a daily basis, one should warm up the model for several tidal cycles to achieve a repeating solution. The time step needs to be small enough to resolve the boundary conditions and conform to stability requirements.
    Michael
