Welcome to the RAS Solution Forums HEC-RAS Help Pumping station
  • #6202
    Hello.
    I need to perform simulations of work pumping station (3 pumps) located at the levee. The feed to the pumping station is a channel which drain into the river – the receiver is using just pumping. What system to use? As a levee use inline structure without a gate or culvert? I created a model: reach inlet -> river receiver (node). I put on the canal pumping station followed by the inline structure without a gate and culvert (weir elevation is the height of the levee crown). Unfortunately, such a system model does not work. The water level in the channel inlet is at the same height – the height of the crown levee. Does anyone have an idea how to do such a model?
    Best regards.
    Wojciech
