Welcome to the RAS Solution Forums HEC-RAS Help Pump Stations from RS to RS
  • This topic has 0 replies, 176 voices, and was last updated 8 years ago by Anonymous.
  • #6780
    I’m currently modeling a bifurcating canal that is pumped from a lower elevation up to a higher elevation. I think I have set everything up correctly but when I go to run a simple steady flow simulation there is no water being pumped through the stations. What are all the requirements for a pump station to work? There’s not much in the user manual explaining how to use them, especially in this specific situation. Thanks!
