Welcome to the RAS Solution Forums HEC-RAS Help Projection File Scale Factor
  • This topic has 0 replies, 264 voices, and was last updated 9 years ago by Mike.
  • #6220
    Mike
    RAS Mapper does not accept ESRI projection file with a scale factor applied. However, if I remove the “PARAMETER[“Scale_Factor”,1.000054673],” from the projection file, RAS will accept it. Anyone else having issues like this?
