Welcome to the RAS Solution › Forums › HEC-RAS Help › Projection error in 6.1
  • #15130
    G MacDonald
    Hi all,
    Has anyone else gotten a similar projection file error message when using RAS Mapper in v6.1? I’m using a projection file from the ESRI website that works with no errors in RAS 5.0.7 and other previous versions. It’s just in v6.1 where I’m getting this error.
    It seems like the model still runs fine in v6.1 despite this message.
    _____________________
    *Corrupt Projection*
    GDAL issued a warning that this projection file is corrupted. You may experience problems using HEC-RAS with this projection file.
    #15294
    Max Goldman
    I have run into the same issue. I was wondering if you managed to find a solution to this.
    M
    #15355
    Wick
    I’ve gotten an error once, but bypassed it and it didn’t seem to affect the results.
    #15389
    G MacDonald
    Yeah I agree with Georgette.
