Welcome to the RAS Solution Forums HEC-RAS Help Profiles in a 2D model
  • #7175
    Paolriv
    I’ve model a river just with a 2D mesh. When i want to watch WSE profiles along the river, in some specific points, specially in curves, i get weird profiles. I’m not sure if that is normal because of the curve.
    For example, this profile is from the cross section showed:
    I will appreciate your help.
    #11999
    Lonnie A
    I’m guessing you are running the full momentum equation and seeing the effect of super elevation around the curve.
