Hi all, I am trying to model a channel. There is no problem on cross section part as seen in the image. But when I click the profile plot, I see just lines without water and elevations are zero.
What is wrong with this?
If someone else needs help about this, I have found the solution. Click options tab on profile plot and then select scaling. Then re arrange the Y axis maximum value. Mine was smaller than my original elevation, so I could not see the elevations and water surface.
