Welcome to the RAS Solution Forums HEC-RAS Help Problems with the Summary Output Tables by Profile
  • #7765
    marinarf95
    Hello everyone!
    I’m trying to perform an unsteady flow simulation in a very steep river using HEC-RAS 5.0.4 (mean slope of approximately 7%).
    To do that, I’m using a Modified Puls Routing on the steepest part of the river. For low flows, the simulation became unstable. But when I set a minimum value, the simulation ends without any problems. The problem is that when I analyze the results in the Summary Output Tables by Profile, all the data are fixed in some specified value as specified in image 1 (the input hydrograph is shown in image 2).
    I tried to run a simulation without using the Modified Puls Routing, but inserting an inline structure to represent the drops in the bed profile, but the tables continued to show the same values. When I analyze the results in RAS MAPPER, the data seem to be ok.
    What could be the source of this problem?
    Thank you very much for your attention!
    Any help on this issue is much appreciated.
    #12951
    I would switch to using the most recent version of HEC-RAS (5.0.7) and see if that makes any difference.
    When you turned of modified pulse, did you just uncheck the box or did you delete all of the regions as well?
    #12952
    marinarf95
    Return-Path:
    by sloti21d1t10 (Cyrus 3.3.0-355-g3ece53b-fm-20200922.004-g3ece53b9) with LMTPA;
    Tue, 29 Sep 2020 17:13:18 -0400
    X-Cyrus-Session-Id: sloti21d1t10-1601413998-71294-2-1939373525297572901
    X-Sieve: CMU Sieve 3.0
    X-Spam-known-sender: no
    X-Spam-sender-reputation: 500 (none)
    X-Spam-score: 1.3
    X-Spam-hits: FREEMAIL_ENVFROM_END_DIGIT 0.25, FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001,
    ME_SENDERREP_NEUTRAL 0.001, RCVD_IN_DNSWL_NONE -0.0001,
    RCVD_IN_MSPIKE_H2 -0.001, RCVD_IN_UNSUBSCOREBL 1, SPF_HELO_PASS -0.001,
    SPF_PASS -0.001, URI_HEX 0.1, LANGUAGES en, BAYES_USED none,
    SA_VERSION 3.4.2
    X-Spam-source: IP=’40.92.20.86′,
    Host=’mail-bn8nam11olkn2086.outbound.protection.outlook.com’,
    Country=’US’, FromHeader=’br’, MailFrom=’br’
    X-Spam-charsets: plain=’iso-8859-1′, html=’iso-8859-1′
    by compute1.internal (LMTPProxy); Tue, 29 Sep 2020 17:13:26 -0400
    by mailmx.nyi.internal (Postfix) with ESMTP id CFE5F1CE0059
    for ; Tue, 29 Sep 2020 17:13:25 -0400 (EDT)
    id 54680FF5234;
    ARC-Seal: i=2; a=rsa-sha256; cv=pass; d=messagingengine.com; s=fm3; t=
    1601414005; b=fXz+9gjA+M8nBqo/l3snC9Ka0f56abrblWtOr1caRif9HPF777
    0Ftd0JhukH/j0dttqS3BNPQ2TLo+N0INy0jStEjNDdSxwto/P1dt+71byl2gIypQ
    xTc0FbkfP+8qzP4tOj2ZOL2biIkO7oxUbyPV3kYGYvR38dhagwQK+18z4xS5KQ9S
    rTbSuOaaT8x9GSKT34MT6gw4l7AeZZRl+K+MbhK9R2r6y3xkOhjk0YAJHf6EM4SY
    DiaChHd8IH8/nrO+FTqRmF2RYd/bkKf+paB4Ci2s/5vruh0M6ng+K4e5nIKR91ZN
    mSHmJoCiPI/aRUcnYJObTGdpSdTBJK/NRGqQ==
    ARC-Message-Signature: i=2; a=rsa-sha256; c=relaxed/relaxed; d=
    messagingengine.com; h=from:to:subject:date:message-id
    :references:in-reply-to:content-type:mime-version; s=fm3; t=
    1601414005; bh=Yqu4RBH6lER68y1UsLxtp9jDHT4eCYcyTfCXnxivW7s=; b=Z
    pAWQWX8ZooE85zBO/AmFgYNeXHpTeMftMi1UV6sFIroXqMdIGyyYBczc/vtJPKMP
    0sOHHay6pPArFlIa3Xs9LIkv7wDR/jDgoYoCPbTWpGDC3cQ58ya71YqFLAu8X6Bm
    eyjQaL52cnb9mN7Rn6bmP1T+J+GujqEQvkHEeG2eDzjp6q3ZfNBWIYAHStXUAScM
    nJaW8LUpjke3dyjOkP7iwuFmn8tCQXxxm3YmqEobsSswTf34NYLg8VmtMSmg6lC3
    1rrm3/a0t2StwVJLUVFwhpJ9iNvu7kSsTDVZOoEZ2GASKt2nM5N/i5nC9eXCsJH5
    4qfFdmwrCYYE2Krk9BqQw==
    ARC-Authentication-Results: i=2; mx4.messagingengine.com; arc=pass (as.1.microsoft.com=pass, ams.1.microsoft.com=pass)
    smtp.remote-ip=40.92.20.86;
    bimi=none (Domain is not BIMI enabled);
    dkim=none (no signatures found);
    (p=none,d=none,d.eval=none) policy.policy-from=p
    header.from=hotmail.com.br;
    iprev=pass smtp.remote-ip=40.92.20.86
    (mail-bn8nam11olkn2086.outbound.protection.outlook.com);
    spf=pass [email protected]
    smtp.helo=NAM11-BN8-obe.outbound.protection.outlook.com;
    x-ptr=fail smtp.helo=NAM11-BN8-obe.outbound.protection.outlook.com
    policy.ptr=mail-bn8nam11olkn2086.outbound.protection.outlook.com;
    x-return-mx=pass header.domain=hotmail.com.br policy.is_org=yes
    (MX Records found: nam.olc.protection.outlook.com);
    x-return-mx=pass smtp.domain=hotmail.com.br policy.is_org=yes
    smtp.bits=128/128;
    x-vs=clean score=0 state=0
    smtp.bits=128/128;
    xhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmbm9kZT05
    MjM0JmNvZGU9YldGeWFXNWhjbVk1TlVCb2IzUnRZV2xzTG1OdmJTNWljbnc1TWpNMGZEaz
    JNekkwTURFMk13PT0
    X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgedujedrvdekgdduiedtucetufdoteggodetrfdotf
    fvucfrrhhofhhilhgvmecuhfgrshhtofgrihhlpdggtfgfnhhsuhgsshgtrhhisggvpdfu
    rfetoffkrfgpnffqhgenuceurghilhhouhhtmecufedttdenucenucfjughrpefhvffuth
    ffkfhfjggtggesrgdttdertddtudenucfhrhhomhepofgrrhhinhgrucftvghfrghtthhi
    ucfhrghguhhnuggvshcuoehmrghrihhnrghrfhelheeshhhothhmrghilhdrtghomhdrsg
    hrqeenucggtffrrghtthgvrhhnpeevkeegleduteeludeuffeliedttedugfdtkeeftdet
    tdekfeevvedtueejuedvkeenucffohhmrghinhepnhgrsggslhgvrdgtohhmnecukfhppe
    egtddrledvrddvtddrkeeipddvrgdtudemudduudemvgegtddtmehftgegsgemmeegleen
    ucevlhhushhtvghrufhiiigvpedtnecurfgrrhgrmhepihhnvghtpeegtddrledvrddvtd
    drkeeipdhhvghloheppfetofduuddquefpkedqohgsvgdrohhuthgsohhunhgurdhprhho
    thgvtghtihhonhdrohhuthhlohhokhdrtghomhdpmhgrihhlfhhrohhmpeeomhgrrhhinh
    grrhhfleehsehhohhtmhgrihhlrdgtohhmrdgsrhequcfukfgkgfepudeikeekfe
    X-ME-VSScore: 0
    X-ME-VSCategory: clean
    Received-SPF: pass
    (hotmail.com.br: Sender is authorized to use ‘[email protected]’ in ‘mfrom’ identity (mechanism ‘include:spf-b.hotmail.com’ matched))
    identity=mailfrom;
    client-ip=40.92.20.86
    Received: from NAM11-BN8-obe.outbound.protection.outlook.com (mail-bn8nam11olkn2086.outbound.protection.outlook.com [40.92.20.86])
    ARC-Seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none;
    b=bmyxDNR2UHfbw4f6F1I3OvaZqUIApIxZWi26TgV26yUsbHYz8rOKougp7Aw1b/MUKDsD6ObAi7DmRZmBzhDKHzwJ4s0xuNAYUaySramdgSiruW25qra5Va/Te23Z+j4nNba8PrlTZ8YT14ttqGAhswQqqtmS4aSK3wvflySaMrJ7NE5SDzYt2w2z6aErEX8wUUAxFx6AvpWbXAbKtYBD/1JNJ4H91N9IUtRbpc6zCjAHfuEe+o/2K8jXPi9+WLezXRWS8AiTNzWConPd/kNavNN72I1b2gvyuiDsf+qUuPsIi/S5hNmNhozW6nHY5sssnq5zmbfNme6xjWDGzaHdyQ==
    ARC-Message-Signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com;
    s=arcselector9901;
    h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck;
    b=gf08/uxU69VuMoy6pGXsoD3DORZBoSHy940Zo/js/cwVeQmla+gC50uaz3KUXYwN0/LIJCc3IuUyr4CvwDEOoJ6vMQRE4+U3HQrrjW26oEYFSGENLT+D8Lkm6uIOqZY47JbF6Fjxi8VNdmrWI8rBgxErtEK6f6V2JReMEXXvL7FaCj0V/8Q9idAi//InShls7LlRpQgJV8G8z0LnDJJwYotmqJzCgY08XWGEYYJUQQS6PZ2CWNl3Pn9K8tI2onejBai8W9weG23VsBdFz/z0IEqxWo3MtSKgr1Gwgc2ynHa79ZVrU3JlQeQkM+KetoWGcms2R5Al/CjWx8qbUyl4kw==
    ARC-Authentication-Results: i=1; mx.microsoft.com 1; spf=none; dmarc=none;
    dkim=none; arc=none
    Received: from BN8NAM11FT062.eop-nam11.prod.protection.outlook.com
    (2a01:111:e400:fc4b::49) by
    BN8NAM11HT034.eop-nam11.prod.protection.outlook.com (2a01:111:e400:fc4b::259)
    with Microsoft SMTP Server (version=TLS1_2,
    cipher=TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384) id 15.20.3433.35; Tue, 29 Sep
    2020 21:13:23 +0000
    Received: from DM5PR18MB2278.namprd18.prod.outlook.com
    (2a01:111:e400:fc4b::49) by BN8NAM11FT062.mail.protection.outlook.com
    (2a01:111:e400:fc4b::290) with Microsoft SMTP Server (version=TLS1_2,
    cipher=TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384) id 15.20.3433.35 via Frontend
    Transport; Tue, 29 Sep 2020 21:13:23 +0000
    ([fe80::f152:fe99:a107:fdc8]) by DM5PR18MB2278.namprd18.prod.outlook.com
    ([fe80::f152:fe99:a107:fdc8%4]) with mapi id 15.20.3412.029; Tue, 29 Sep 2020
    21:13:23 +0000
    Subject: RE: Problems with the Summary Output Tables by Profile
    Thread-Topic: Problems with the Summary Output Tables by Profile
    Thread-Index: AQHWlmn65Ls8HwnJ8EKbLs/sqnLWT6mAHMS9
    Date: Tue, 29 Sep 2020 21:13:23 +0000
    Message-ID:
    References:
    <[email protected]>,<[email protected]>
    Accept-Language: pt-BR, en-US
    Content-Language: pt-BR
    X-MS-Has-Attach:
    X-MS-TNEF-Correlator:
    x-incomingtopheadermarker:
    OriginalChecksum:5CEDBDA3BB0DE36895A82299296F489C53249F9279C184B7C61214DA93F9D53A;UpperCasedChecksum:1C58C56A92F89BEAFCDE661DAA51157612BF347E8647612BA37D46B685A5DF4D;SizeAsReceived:6903;Count:44
    x-ms-exchange-messagesentrepresentingtype: 1
    x-tmn: [o2OQJGQiB0hl9UPN0D0sDUiArtCMwLkata/QRhIK0lA=]
    x-ms-publictraffictype: Email
    x-incomingheadercount: 44
    x-eopattributedmessage: 0
    x-ms-office365-filtering-correlation-id: 085ad196-7eb0-4244-3470-08d864bc7fbc
    x-ms-traffictypediagnostic: BN8NAM11HT034:
    x-microsoft-antispam: BCL:0;
    x-microsoft-antispam-message-info:
    h53PRiCXbZAOttrgbKERI1u4jhm7qywAQMSTcJ3Phhtzi6MuzwShMM+4JLBbp/ZPbehmPyDvLLUv0NCDE6dd174wUUFQI5IHezchN0MHAx2IVewWnw8HLfWEypYvPDDEKaH04KlqPyjUJ7NahskvoqJkTwLbIC4AfmID7VIDUiQtGA5ae9pjf0p72R6sp6ScbhruxW5/C//4t6G1qxeKmRsZ24b/ofZLj1sRgU6VD1uFxE0LtG9um+hwt7yd/7CJ
    x-ms-exchange-antispam-messagedata:
    +fXWFBRaQv92mdrAJvxbhij9vLIinv6pRAJBixCHb0rx8VQ5p8M519X9O+FHa/rwS2+GRPk9JM9cW5AsaoQ0NnL396kYa2joavvnypePz4pJnyUt1lGunfYGF6V0w27qdQ1Msa87DjGq3n0XXibyOg==
    x-ms-exchange-transport-forked: True
    boundary=”_000_DM5PR18MB2278BF8F9C334E7D8D8FFE67F1320DM5PR18MB2278namp_”
    MIME-Version: 1.0
    X-OriginatorOrg: outlook.com
    X-MS-Exchange-CrossTenant-AuthAs: Anonymous
    X-MS-Exchange-CrossTenant-AuthSource: BN8NAM11FT062.eop-nam11.prod.protection.outlook.com
    X-MS-Exchange-CrossTenant-RMS-PersistedConsumerOrg: 00000000-0000-0000-0000-000000000000
    X-MS-Exchange-CrossTenant-Network-Message-Id: 085ad196-7eb0-4244-3470-08d864bc7fbc
    X-MS-Exchange-CrossTenant-originalarrivaltime: 29 Sep 2020 21:13:23.1865
    (UTC)
    X-MS-Exchange-CrossTenant-fromentityheader: Internet
    X-MS-Exchange-CrossTenant-id: 84df9e7f-e9f6-40af-b435-aaaaaaaaaaaa
    X-MS-Exchange-CrossTenant-rms-persistedconsumerorg: 00000000-0000-0000-0000-000000000000
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: BN8NAM11HT034
    –_000_DM5PR18MB2278BF8F9C334E7D8D8FFE67F1320DM5PR18MB2278namp_
    Content-Type: text/plain; charset=”iso-8859-1″
    Good afternoon Cameron!
    Thank you for your answer.
    I will switch HEC-RAS 5.0.7 and try to do the simulation again.
    When I turned of Modified Puls I uncheck the box and delete all the regions=
    De: cameron [via HEC-RAS Help]
    Enviado: ter=E7a-feira, 29 de setembro de 2020 12:08
    Para: marinarf95
    Assunto: Re: Problems with the Summary Output Tables by Profile
    I would switch to using the most recent version of HEC-RAS (5.0.7) and see =
    When you turned of modified pulse, did you just uncheck the box or did you =
    low:
    http://hec-ras-help.1091112.n5.nabble.com/Problems-with-the-Summary-Output-=
    Tables-by-Profile-tp9234p9250.html
    To unsubscribe from Problems with the Summary Output Tables by Profile, cli=
    ck here<http://hec-ras-help.1091112.n5.nabble.com/template/NamlServlet.jtp?=
    macro=3Dunsubscribe_by_code&node=3D9234&code=3DbWFyaW5hcmY5NUBob3RtYWlsLmNv=
    bS5icnw5MjM0fDk2MzI0MDE2Mw=3D=3D>.
    .view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscribers%21nabble%=
    3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabb=
    le%3Aemail.naml>
    Content-Type: text/html; charset=”iso-8859-1″
    De: cameron [via HEC-RAS He=
    lp] <[email protected]>
    Para: marinarf95 <[email protected]>
    I would switch to using the most recent version of HEC-RAS (5.0.7) and=
    If you reply to this email, your message wi=
    ll be added to the discussion below:
    http://hec-ras-help.1091112.=
    n5.nabble.com/Problems-with-the-Summary-Output-Tables-by-Profile-tp9234p925=
    0.html
    click here
    Author
