Hi!
I’m working on a sediment model in HEC-RAS 4.1.0, using the International System – SI (Metric) and I’m having the following problems:
1) As boundary condition of the model, I’m using a sediment load series. When I verify the “Mass In” output series on the boundaries cross sections, the program always gives me a solid discharge 2.430168 higher than what I determined as boundary condition for each cross section;
2) When I divide (for any given sand range size) the “Mass In” (in tons) of a specific cross section with the “Volume In” (in cubic meters) of this same cross section, I get a density of 127.942346 t/m³, which has an order of magnitude a lot different from the default sand density of the program (1.489 t/m³). This same density (127.942346 t/m³) is found when I evaluate the sediments that pass or the ones who are retained in the cross section.
Can anyone give me an explanation for this problem? Is there any bug on the transformation from mass to volume in this HEC-RAS version?
Camila
