Welcome to the RAS Solution Forums HEC-RAS Help Problems with Puming Station from SA to RS
  • #6696
    Carlos_MartinezG
    Dear all,
    I’m having some problems with a pumoin station that its supposed to pump from a SA to a RS, the on-off controls os the PS is set to activate the pumps when the WS elevetion goes below a reference. The PS actually turn on as I can see in the tables but I dont see the flow going into reach, and in the SA table appear as Inflow the same flow that the PS is pumping. I try doing it pon a simple channel but I got the same result.
    Thank you.
    Carlos
