Hello
I use HEC-RAS V5.07 and have a problem displaying “Plot Terrain” in the Cross Section view of Geometric Data. The moment the terrestrial data are saved, the terrain disappears. If I delete the date, the terrain shows up again.
I exclude wrong coordinate systems because they are not only displayed correctly in the RAS Mapper but also in ArcGIS and I have tested the data in a test project.
In the first test project it works without problems. The only difference between both projects is that I always have to far zoom in of the project area from the test project. The second project is allways displyed correctly (centered).
Does anyone know the problem and has a solution?
Greetings
Gerrit
