Welcome to the RAS Solution Forums HEC-RAS Help problems import shapefile
  • This topic has 5 replies, 692 voices, and was last updated 8 years ago by Anonymous.
  • #6803
    Hello everyone. I inserted the shapefile of the XS sections in Ras Mapper. I can see this file correctly. I open Geometric Data and select layer to view in the background, but I can not see the shapefile. I have created the shapefile with Q gis. I inserted some .tif maps and I see them instead.
    Where am I wrong? Thank you.
    #11231
    Is there anyone who can help me please?
    #11232
    This just sounds like one of those problems that you have to try closing the software and then reopening it. This always solves that problem for me
    #11233
    Thank you very much for your intervention. I tried but I did not succeed. I’m working on an existing non-georeferenced geometry that I imported. I realized that this is very small. I tried to enlarge it but the XS section did not follow the reach. The only solution that comes to mind is to redo the model. Do you have any suggestions to be able to enlarge the reach and the sections together automatically?
    #11234
    PaoloP
    If you are working with RAS Mapper you must work in georeferenced mode, therefore also geometry must be georeferenced.
    To create a georeferenced geometry can be useful utilize RAS Geometry Maker
    PaoloP
    #11235
    I solved the problem. I had to use hec ras 4.1 to be able to position the correct geometry and to scale the reach and XS section dimensions to the desired size. Unfortunately with Hec ras 5.0.3 the coordinates change but the program only updates the reach while the sections always hang in the same position. So I would say that it is a BUG of code 5.0.3 that would be worth pointing out.
