I am experiencing a problem with exporting maps to disk from Ras Mapper. I had already found this problem in version 5.0.3, and I verified that it remained in the new official version 5.0.4.
I ran a plan file and I can correctly see the results in Ras Mapper. Using Ras Mapper to view the maps “on the fly” everything works.
The problem is when I tried to save maps to disk.
First, I saved “Depth Maps” in shape format and everythigs works. I exported single polygons using the following procedure:
1. Open Window “Manage Results Maps” -> Add New Map
2. In “Results Map Parameters” windows I set following parameters:
Map Type = Depth
Unsteady Profile = Maximum
Map Out Mode = Polygon Boundary at Value: 2
Layer name = Depth
3. Press “Compute/Update Stored Maps” bottom
I tried to do the same thing with “Velocity Maps” and I had 2 problem:
1ST: the shape filename is the same for all saved shape file, regardless of the Velocity parameter I set. So, I have to export one file at a time and then I have to manually change his name.
2ND: shapefile does not contain the “Velocity polygon” but the “Depth polygon”.
I do not know how to solve this second issue. Can someone help me?
