Welcome to the RAS Solution Forums HEC-RAS Help Problem with DSS
  • #5668
    Petra
    The program runs and then I get the following messages:
    Writing Results to DSS
    Reading Data for Post Process
    then a pop up window appears and gives me the following message:
    Output DSS File:
    “S:\Hydraulics\Waterway\5\5757\HECRAS\2D\MISSION_123014.dss” does not exist.
    I work for the Minnesota Department of Transportation and the DSS Writer is located on the C drive of my computer. Instead of running the program through the servers, should I be running it on my C drive?
    #9048
    I had the same error, Did you sort it out? Can anybody help me?
    I have donwloaded HEC-RAS 5.0.1
