Welcome to the RAS Solution Forums HEC-RAS Help Problem with changing slope of cross sections
  • This topic has 2 replies, 499 voices, and was last updated 10 years ago by Anonymous.
  • #5971
    I am trying to model the Mississippi River. I have the geometry set to a slope and am using the channel modification editor to change it. It calculates the new invert elevations. When I save the new geometry file, the modifications are not included (its the same exact geometry as before).
    Any suggestions are appreciated. Please and thank you!
    Linsey
    #9620
    This will happen if you dont save the plan & project before you save the geometry
    #9621
    Vince Moody
    It calculates a new channel invert, and then applies the specified channel template to each section at the respective invert. Make sure your channel templates are designed and applied to each section, then click “Create Geometry File with these Modifications”. Also, highly recommend saving the existing geometry in which channel design data is stored, per Luis’ suggestion.
