Welcome to the RAS Solution Forums HEC-RAS Help problem with calculations
  • #7550
    I will make a one-dimensional river model in hec ras 5.0.7. and put in flows and performed simulations.
    Then I connected the river that flows into the modeled river in the upper section.
    Unfortunately, the results of calculations with and without inflow are the same. Now the question. Should I connect the inflow to the main river in boundary conditions manually add the flow from this inflow in the section below the connected inflow to the main river? I was convinced that when I put in the inflow to the main river using junction, these inflows will add up. Unfortunately, this is not the case. Unless I do something wrong?
    Best regards
    Woyrek
