Welcome to the RAS Solution Forums HEC-RAS Help Problem with adding terrain
  • #7831
    htaysi
    Hi all, I am having a strange problem. I am adding *tif file as terrain after adding projection file. But it is turning green with a huge amount of surface values as it is seen below in layer properties. Also, min, max, mean and standard deviation values are difference between *tif and *vrt. What should I do to solve this? Thanks in advance.
    #12990
    benp
    HEC-RAS forgot the dot in your number.
    Maybe a problem of regional setting with dot and comma.
    Look here:
    https://therassolution.kleinschmidtgroup.com/ras-post/region-and-language-settings/
    On my version, I have dot in my numbers, you have coma
    See the same windows for me:
