Welcome to the RAS Solution Forums HEC-RAS Help Problem in exporting RAS Tiles for Web Mapping
  • This topic has 3 replies, 865 voices, and was last updated 8 years ago by Anonymous.
  • #6530
    Hi everyone,
    I used RAS 5.0.3 to perform some 2D unsteady analysis and I would like to export dynamic inundation maps in order to visualize it in Google Earth Pro.
    So I tried the RAS Tiles Export process to obtain a .db cache file (2D Modeling User’s Manual – 5_11), defined Cache Level, profiles interval and select output directory and name, but nothing happened.
    When the process starts, it gives back a blank Compute Window for hours, whether if I choose a very short profile interval or longer to export. Moreover, trying to close this compute window causes a Not Responding problem in HEC-RAS.
    It’s a sort of bug of the software or I got something wrong?
    Another question : as I understand it, with the Result Map Parameters windows I can only create static maps or shapefile. Is it possible to export videos or similars?
    Thank you!
    Haldo
    #10716
    Paul Meems
    Did you even found a solution?
    I’m trying to do the same with v5.0.5 and nothing happens.
    #10717
    You have to download some additional files at the location below for it to work.
    http://www.hec.usace.army.mil/software/hec-ras/downloads.aspx
    #10718
    Yea its still kind of vague. Ive never been successful at it either
    If anyone has a way or step by step instruction please post it here. (the corps step by step wasnt good enough for me)
