Welcome to the RAS Solution Forums HEC-RAS Help Problem exporting cross-sections from civil 3D
  • #7279
    hello, I have a problem exporting sections from civil 3D, this happens after having made changes to the corridor I’m using to modify the terrain, but it’s not a direct change to the alignment or to the sections already chosen, after exporting the sections in hec-ras format with the command “exporthecras”, when importing them into the program I get a bad reading of the river axis “river reach”, I’m attaching the file so you can visualize the error and help me understand what happens, thank you.
    i dont know if its allow to share links, but here it is.
    https://drive.google.com/open?id=14ZzbDHNn69vfQIwFeaIR7NuhyfLYmmy5
