I am modeling a bridge where the 100 year storm event approaches the low chord of the bridge. There is a risk of pressure flow at this storm event.
The design of the bridge is dependent on the hydrology, so several different structural members have been modeled with varying low chords.
In HECRAS there is an option for pressure flow criteria: energy gradeline or water surface elevation. Is there a recommendation of what option to use and under what circumstances?
If using the energy gradeline, when the low chord meets the gradeline, the water surface will essentially jump and cause pressure flow. Is there any reason why?
Thanks in advance!
