Welcome to the RAS Solution › Forums › HEC-RAS Help › Precipitation results differ on every run
Tagged: HEC-RAS, precipitation, rain on grid, rainfall, random, stochastic
- This topic has 8 replies, 2 voices, and was last updated 4 years, 8 months ago by Luis Partida.
July 13, 2021 at 5:32 pm #14733Rhys McIntoshParticipant
Hi all,
I’m running a simple model in HEC-RAS 5.0.7 with only precipitation and normal depth boundary conditions. Every time I run the model with identical conditions, files etc the flooding extents differ slightly. Is there some sort of stochastic/random process going into the rainfall distribution in HEC-RAS? This is something that I would like to eliminate as I want to compare flooding extents for two scenarios. Does anyone else have the same issue?
Thanks for your help,
Regards,
RhysJuly 13, 2021 at 6:58 pm #14735Luis PartidaParticipantI have never seen this happen. One option is to put a link here with the model zipped up and i would be happy to give it a look
July 13, 2021 at 10:22 pm #14736Rhys McIntoshParticipantHi Luis, thanks for the reply, it’s much appreciated! Here’s a Dropbox link to my model in its simplest form – https://www.dropbox.com/s/a6heq09e4q0x4om/Precip_model.zip?dl=1 . As you’ll see in the mapper there are two results that are slightly different, they were run one after the other with no changes.
July 14, 2021 at 1:43 pm #14739Luis PartidaParticipantRhys, i solved the problem. Thank you for providing the model for review. The issue is your break line spacing being 5 and 5 on a 50×50 meter mesh. While i cannot explain why the results differ, when i removed those breaklines the results are the same and your error is resolved.
I would instead try and utilize a refinement region rather than breaklines, this can be done in RAS Mapper. You have to remember that your time step and cell spacing are variables within satisfying the courant condition. If you have a variance from 5 to 50 i would expect to see issues. I see no reason the resolution would require that small of a cell size but i dont know the scope of your project. Anyways, hope this helps.
July 15, 2021 at 5:44 pm #14742Rhys McIntoshParticipantHi Luis,
Thank you so much for having a look! I tried your suggestion of removing the jump from 50m to 5m by adding a 15m refinement region between the 50m perimeter and the 5m inner refinement region but I still can’t get the same result twice. Is there any chance you could please send me the modified model you made? It’d at least be a starting point I could work from.
By the way the reason why I need such resolution is because we’re looking at the flooding on a potential subdivision, so we need to resolve roads, stopbanks etc.
July 16, 2021 at 1:31 pm #14744Luis PartidaParticipantRhys, again, it is not meant to be done with breaklines. You must use refinement regions. I just did it with a 15×15 refinement region and the results of both are the same. Again do not use breaklines. Open RAS Mapper and under geometry expand your 2D flow area>Refinement region. Then edit and draw the polygon, then open the properties and for the dx dy enter 15. Close, right click refinement region “Enforce All Regions”
July 16, 2021 at 3:03 pm #14745Luis PartidaParticipantSend me a link i will upload my model
July 20, 2021 at 6:17 pm #14753Rhys McIntoshParticipantHi Luis,
I apologies for the late reply and thank you for all of the effort you put into this. I think I figured out what my issue was. I was able to replicate two identical model runs by dropping the timestep way down to 0.3 s. From what I understand the model was still running through instabilities and looking at the maximum flood extents was showing a lot of these instabilities, which weren’t consistent between model runs.
July 23, 2021 at 9:28 am #14756Luis PartidaParticipantRhys, a 0.3 sec d(t) should almost never be required especially for that mesh and cell sizes. I would re-evaluate that model
