Welcome to the RAS Solution › Forums › HEC-RAS Help › Power of HECRAS 5
- This topic has 5 replies, 814 voices, and was last updated 10 years, 6 months ago by Michaeltay.
August 29, 2015 at 8:56 pm #5864MichaeltayParticipant
Using 2D MESH to model flow across skew bridge In HECRAS 5
https://www.youtube.com/watch?v=7KZaOB3tB0kAugust 29, 2015 at 9:37 pm #9484Chris G.KeymasterReturn-Path:
Received: from mail-pa0-f46.google.com (mail-pa0-f46.google.com [209.85.220.46])
by mbob.nabble.com (Postfix) with ESMTP id E9DB5144BBDA
for; Sat, 29 Aug 2015 09:35:21 -0700 (PDT)
Received: by pabzx8 with SMTP id zx8so93373544pab.1
for; Sat, 29 Aug 2015 09:37:57 -0700 (PDT)
d=gmail.com; s=20120113;
bh=0WWV4oF3foQGZwVIpHAXxhTqZsY/VQOPzlv3JzpzUC8=;
b=P1SDSo93oUqFWzIlRrResXFHO14Qu/W3+Ae1rwZnBcOtuP3RK/NoUL+GUYgw75PZ/F
VDctwjPz89WUIKuNGe7PDK+0WKhUkUvfcMseFWk40UBnFht02PsGLSlMT/vYoI7MOdKH
VFJrOjlb5W82CnZSExq9qMxANSg8/jaDG8hoK+zMaAIFCkseUb5nFdZ8cj7bJejm60sd
J94df7Q8BDD+6y+2bqDRVHOJ8jd+VYnSuk345XhA4HGuDNId9ft1Zpekh7ujCWqViozP
BmTJcga1097l8ctYTjF/Zfpo++A9s+JHRYe8YOUWhIbY+E2V9lM+FblT4Fj4MT2GTuLD
FRLg==
X-Received: by 10.66.226.12 with SMTP id ro12mr24449444pac.74.1440866277306;
Received: from [100.67.57.46] (176.sub-70-210-138.myvzw.com. [70.210.138.176])
by smtp.gmail.com with ESMTPSA id yu2sm9190414pac.33.2015.08.29.09.37.55
for
Sat, 29 Aug 2015 09:37:56 -0700 (PDT)
Subject: Re: Power of HECRAS 5
boundary=Apple-Mail-AD2C2106-3F0C-4690-8001-549BC17CFBD6
X-Mailer: iPhone Mail (12D508)
Date: Sat, 29 Aug 2015 09:37:54 -0700
To: “Michaeltay [via HEC-RAS Help]”
Mime-Version: 1.0 (1.0)–Apple-Mail-AD2C2106-3F0C-4690-8001-549BC17CFBD6
Content-Type: text/plain;
charset=us-ascii
Content-Transfer-Encoding: quoted-printableThat’s cool. Can I post it on The RAS Solution? If so, can you give me some=
details? Eg. Cell Size, time step, simulation time, diffusion wave or full=
momentum, etc. thanks
ChrisSent from my iPhone
> On Aug 29, 2015, at 08:56, Michaeltay [via HEC-RAS Help]
wrote:
>=20
> Using 2D MESH to model flow across skew bridge In HECRAS 5=20
> https://www.youtube.com/watch?v=3D7KZaOB3tB0k=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/Power-of-HECRAS-5-tp1940.html
> NAML–Apple-Mail-AD2C2106-3F0C-4690-8001-549BC17CFBD6
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: 7bitThat’s cool. Can I post it on The RAS Solution? If so, can you give me some details? Eg. Cell Size, time step, simulation time, diffusion wave or full momentum, etc. thanksChrisSent from my iPhone
On Aug 29, 2015, at 08:56, Michaeltay [via HEC-RAS Help] <[email protected]> wrote:Using 2D MESH to model flow across skew bridge In HECRAS 5
If you reply to this email, your message will be added to the discussion below:http://hec-ras-help.1091112.n5.nabble.com/Power-of-HECRAS-5-tp1940.html
NAML
–Apple-Mail-AD2C2106-3F0C-4690-8001-549BC17CFBD6–August 29, 2015 at 10:39 pm #9485MichaeltayParticipant1mx1m cell size, time step of 30 second using full momentum. Sure you could post it. I have posted a version of normal crossing and a version with downstream tidal effect.
September 15, 2015 at 6:09 pm #9486AnonymousGuesthow to import .2dm file in Hec ras 5
September 15, 2015 at 7:29 pm #9487cameronParticipantYou can’t import a 2dm file into HEC-RAS 5.0 that I am aware of. Most 2dm files are triangular meshes and HEC-RAS does something different when meshing. Also one of the advantages of HEC-RAS 5.0 is you don’t need as small as elements as other 2D models.
June 8, 2018 at 1:38 am #9488RunoffParticipantCameron is right, .2dm files typically contain triangular or quadrilateral elements, however, using the SMS software developed by Aquaveo, you can convert .2dm files to the RAS geometry format and load that into RAS 5.0. It works well and does preserve the triangular or quadrilateral cell configuration, you just have to be careful not to make any changes to the “2D flow areas” options after importing it into RAS, as RAS will regenerate the mesh and build a different configuration of cell edges.
