Welcome to the RAS Solution Forums HEC-RAS Help PostProcessing ArcMap [ESRI]
  • #5540
    Robert
    Hi everybody
    I was trying to import ,dam.RASexport.sdf’ to ArcMap 10 [ESRI].
    Steps:
    1. Convert RAS Export SDF to XM- successfully completed
    2. Layer Setup for Hec-RAS PostProcessing- successfully completed
    3. Import RAS Data- unsuccessfully
    Do you have experience with this problem?
    Therefore I was doing postprocessing in the ArcView 3.2 [successfully].
    But postproccesing in ArcMap has capability Visualization (2D Animation or publish KML) and ArcView hasn’t.
    greetings
    Robert
    #8855
    Ensure your map is in the same coordinate system as the RAS model. Also if the process persists I have found that sometime you have to move the files to a location on your hard drive vs a network server to work.
    #8856
    another option would be to use RAS Mapper to generate the floodplains and then import the shapefiles to ArcMap.
