Welcome to the RAS Solution Forums HEC-RAS Help Post-Process freezes
  • This topic has 1 reply, 294 voices, and was last updated 11 years ago by Anonymous.
  • #5734
    I have been running RAS models for years. I have developed a complex unsteady model that I’ve been running for a few months without any issues. At some point along the way, the post process started to freeze. It’s almost as though something got corrupted along the way. The unsteady flow simulation runs without any problems but the post-process freezes before it finishes processing (seems to always stop at the same point and it has no problems reading in the data from the .dss file). I have tried several things, including 1) changing simulation start and end dates 2) running post processor separately from the unsteady flow simulation 3) starting a fresh project and plan file. None of these have worked. Any suggestions would be welcomed.
    Thank you.
    #9176
    Alex Curran
    Was this ever solved? I have encountered the same problem using 5.0.3
