Welcome to the RAS Solution Forums HEC-RAS Help Possible to resume calculations after error?
  • #7290
    My HEC-RAS model threw an error yesterday when it lost the connection to the server where the model files are stored.
    It created a restart file after the error; is it possible to resume my calculations using this file or in any other way?
    Thanks in advance!
    #12217
    Scott Miller
    Give it a try by choosing the quick start file where you would set the initial conditions. Choose a start time that makes sense for your computation and output intervals. Restart the model under a new plan, because there will be output only for the remaining period.
    I find it preferable to model locally, on a C: drive or peripheral hard drive, in order to reduce bottlenecks that affect computation speed. Doing so also eliminates the potential to lose a server connection.
    #12218
    Thank you for your response Scott.
    The issue is that this way I don’t get any results from before the error, and I need those too..
    I’ll take a look again at the possibilities for storing the files locally, thank you for the tip.
