Welcome to the RAS Solution Forums HEC-RAS Help Polygon error – please inspect your perimeter for duplicate points
  • This topic has 2 replies, 419 voices, and was last updated 6 years ago by Anonymous.
  • #7473
    I am trying to create ‘.G**’ file externally using Python, and partially successful to load the file with the following error, Mesh ‘Perimeter 1’: Polygon error – please inspect your perimeter for duplicate points.
    Could you help in understanding the error and its rectification, please??
    Thank you.
    #12547
    ckatsoulas
    You have created a polygon that has at least two points/vertices sitting on top of each other on the same co-ordinate. You may have accidentally clicked twice when creating the polygon for the 2D area. You need to edit the polygon and delete the duplicate point.
    #12548
    Yes..! you’re right. Now I’m able to remove the error with your kind suggestion.
    Thank you.
    Ramesh
