Welcome to the RAS Solution Forums HEC-RAS Help Polygon Boundary At Value “X” not working for Velocity
  • This topic has 2 replies, 90 voices, and was last updated 6 years ago by Anonymous.
  • #7568
    I am attempting to create velocity “contours” for a project. I did this for depth, and it worked great. I went to results map parameters, selected depth, selected maximum (unsteady profile), then “polygon boundary at value X”, where x is the value I wanted. This generated depth contours at the specified intervals I needed.
    Now when I do the exact same thing, but for velocity, no matter what value I type in for X, it only generates a maximum velocity polygon. Anyone else have this issue? Is there a workaround? I am using HEC-RAS version 5.0.7.
    Thanks!
    Brian
    #12676
    shant
    Hi Brian,
    Were you ever able to resolve this? I’m experiencing the same exact issue. Thanks!
    #12677
    mowens
    I’m also having this issue. Has a solution been found?
