Welcome to the RAS Solution Forums HEC-RAS Help Plot data for Weirs in a 2Dmesh
  • #6952
    SaraA
    I am creating a 2D model for a entire river using a 2D mesh in which I am introducing some weirs using the tool 2D Area breaklines.
    I ran the model and I can see the resuls in RAS Mapper of Depth, WSE and velocities, but when I want to consult the profile of the weirs as Plot Stage and Flow Hydrographs/types/SA-2D connections, the Conn name (Conn:) appears, but the data is empty.
    I followed the indications of Chris in this post: http://hecrasmodel.blogspot.com/2015/09/transect-for-extracting-flow-in-2d-area.html
    It could be that the reason for not seeing the data is because I am introducing the weirs as 2DArea break lines, instead of SA/2D area connections? I ensure that in the connection editor of the weir I connect from/to with the same 2D mesh for my entire river.
    Someone is facing the same issue?
    Thank you,
    Sara
    #11501
    They would have to be area connections
