Welcome to the RAS Solution Forums HEC-RAS Help Plan files disappearing
  • #6978
    eric1
    Hello everyone,
    I am currently having some troubles with the plan files. I am working on one project and I launch several plans at the same time (1D/2D modeling). When the computation is done, I save each plan. Then, when I open the project once again, not all the plan files are visible through the plan window (file / open plan). It is the same in the Ras Mapper windows.
    I saw that depending from which plan I save the project file last, when I re-open the project the remaining plan files are not the same.
    How can I avoid to loose the plan files while at the same time launch the computation of several plan files at the same time? I can always re-open the geometry and hydrology files and re-launch the plan but it is time consuming (computation time is 24 h on average). I do not really understand the way Hecras work with the saving of the files,….
    Thank you in advance,
    Eric
