I have some problems performing an unsteady flow analysis. When computing I recieve an error message for the unsteady post processor:
“Error reading data from path: /WORD1 WORD2//LOCATION-FLOW//MAX STAGE/TEST1” Path not found
I have got the project including geometry file from a friend to perform the unsteady analysis. Problem is that there are no file/folder called “word1 word2” to be found on the computer (neither on mine or his), and the path is completely different from the path on which I saved the project (including the plan).
It does not help if I do save plan as.
How can I change the path to search in a specific directory which does exist?
