Welcome to the RAS Solution Forums HEC-RAS Help Overlapping cross-sections although downstream reach length not zero
  • #6147
    I have a model where 4 cross-sections (there is also a culvert in between two of those) overlap. Downstream reach lengths are not zero. In the profile these sections and the culvert appear as they should be but in the Geometric Data in the horizontal layout they overlap.
    Is there a way to fix this?
    Thank you
    #9994
    How were the cross-sections created? Did you use GeoRAS? What was the horizontal projection of the model?
