Welcome to the RAS Solution › Forums › HECRAS Controller › OUtput_Nodeoutput only read out the first plan file in the loop
- This topic has 3 replies, 573 voices, and was last updated 9 years, 5 months ago by hillwinner.
October 14, 2016 at 7:25 pm #8187hillwinnerParticipant
Hi Chris,
I have the code to batch run RAS and read out the stage for a multi-plan project. I set a loop (Line 63), RAS runs for different plans (plan 5 and plan 6) but the Output_Nodeoutput always read out the first plan (plan 5 only and didn’t read plan 6). Anyone can see anything I did wrong in the code?
Shan
The code as Follows:
————————————————————–Sub BatchRunAndPostprocess()
Dim strProjectFileName As String
strProjectFileName = “C:\” & _
“RAS_BatchRuns0915\runs” & _
“\XS-1916\XS-1916.prj”‘Open the HEC-RAS project
Dim RC As New HECRASController
RC.Project_Open strProjectFileName‘Determine the number of plans
Dim lngPlanCount As Long
Dim strPlanNames() As String
Dim blnIncludeOnlyPlansInDirectory As Boolean
RC.Plan_Names lngPlanCount, strPlanNames(), blnIncludeOnlyPlansInDirectory‘Determine the number of RS’s in River 1 and Reach 1
Dim lngNumRS As Long
lngNumRS = RC.Geometry.nNode(1, 1)‘Get River Stations
Dim strRS() As String
Dim strNodeType() As String
RC.Geometry_GetNodes 1, 1, lngNumRS, strRS(), strNodeType()‘Output the River Station ID and Plan Names
‘ to RiverStationID sheet.
Dim i As Long, j As Long
Dim blnSheetExists As Boolean
For i = 1 To Sheets.Count
If Sheets(i).Name = “RiverStationID” Then
blnSheetExists = True
End If
Next i
If blnSheetExists = False Then
Sheets.Add
ActiveSheet.Name = “RiverStationID”
End If
Sheets(“RiverStationID”).SelectFor i = 1 To lngNumRS
Cells(i, 1).Value = i
Cells(i, 2).Value = strRS(i)
Cells(i, 3).Value = strNodeType(i)
Next i‘Cells(1, 4).Value = lngPlanCount
For i = 1 To lngPlanCount
Cells(i, 4).Value = i
Cells(i, 5).Value = strPlanNames(i)
Next i
‘Run HEC-RAS and Postprocess by loop throughDim blnSetIt As Boolean
Dim lngMessages As Long
Dim strMessages() As String
Dim blnDidItCompute As BooleanFor iplan = 5 To 6 ‘lngPlanCount
blnSetIt = RC.Plan_SetCurrent(strPlanNames(iplan))
RC.Project_Save
RC.Project_Open strProjectFileNameblnDidItCompute = RC.Compute_CurrentPlan(lngMessages, strMessages())
‘Determine the number of profiles
Dim lngNumProf As Long
Dim strProfileName() As String
RC.Output_GetProfiles lngNumProf, strProfileName()MsgBox “Current PlanName=” & strPlanNames(iplan) & ” nProfile=” & lngNumProf
‘Get initial stages. Uses profile number 2, since profile
‘ number 1 is the MaxWS profile. number 2 is 1st initial
Dim sngMaxStage() As Single: ReDim sngMaxStage(1 To _
lngNumRS)
Dim lngNVar As Long
lngNVar = 2 ‘Output ID # for W/S Elevation
Application.StatusBar = “Getting maximum stage ” & _
“for node ID ” & i & “.”
sngMaxStage(i) = RC.Output_NodeOutput(1, 1, i, 0, 1, _
lngNVar)
Next i‘First check to see if the worksheet “strPlanName”
‘ already exists. If not, add a new sheet and name it.
If Sheets(i).Name = strPlanNames(iplan) Then
End If
Next i‘If “RASResults” does not exist as a sheet, we’ll
‘ add it.
Sheets.Add
ActiveSheet.Name = strPlanNames(iplan)
End If
Sheets(strPlanNames(iplan)).Select‘Clear all the data so that can construct a fresh table _
of data.
Cells.Select
Cells.Delete‘Give the first column header.
Range(“A1”).Select
ActiveCell.Value = “DateAndTime”
For j = 2 To lngNumProf
Cells(j, 1).Value = strProfileName(j)
Next j‘Go through each cross section and profile
‘ to assign value to 2-d array for selected RS
Dim lngNumSelectedRS As Long
lngNumSelectedRS = 7Dim lngSelectedRS() As Long: ReDim lngSelectedRS(1 To lngNumSelectedRS) As Long
Dim sngTmpStage As Single
Dim sngStage() As Single: ReDim sngStage(1 To _
lngNumSelectedRS, 1 To lngNumProf)
lngSelectedRS(1) = 228
lngSelectedRS(2) = 221
lngSelectedRS(3) = 189
lngSelectedRS(4) = 152
lngSelectedRS(5) = 130
lngSelectedRS(6) = 109
lngSelectedRS(7) = 7
For i = 1 To lngNumSelectedRS
Cells(1, i + 1) = strRS(lngSelectedRS(i))
Application.StatusBar = “Reading ” & _
“Plan ” & strPlanNames(iplan) & _
” River Station ” & i _
& “of ” & lngNumSelectedRS & “, ” & _
“Profile ” & j & “.”
sngStage(i, j) = RC.Output_NodeOutput(1, 1, _
lngSelectedRS(i), 0, j, 2)
Cells(j, i + 1).Value = sngStage(i, j)
Next j
Next i‘Finish
Next iplan
‘MsgBox “Done!”
Application.StatusBar = “Finished!”
‘RC.QuitRASEnd Sub
June 19, 2018 at 4:41 am #13516AnonymousGuestI came across this question while searching for a solution to my own problem. I was having trouble looping through already computed plans changing them with .PlanOutput_SetCurrent and .Plan_SetCurrent then extracting results using .Output_NodesOutput . It just seemed like the output file was not being updated. The solution was to change the plan, save it, close the project and then re-open it:
RC.Plan_SetCurrent (strPlanNames(j))
RC.Project_Save
RC.Project_Close
RC.Project_Open strRASProjectHopefully this will save someone the time it took me to figure this out…
June 19, 2018 at 11:43 pm #13517Chris G.KeymasterReturn-Path:
by sloti1d2t14 (Cyrus 3.1.3-653-gce35ffd-fastmail) with LMTPA;
Tue, 19 Jun 2018 15:43:53 -0400
X-Cyrus-Session-Id: sloti1d2t14-4182396-1529437433-2-15320352326950809254
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-score: 0.0
X-Spam-hits: BAYES_00 -1.9, FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001, ME_BETA_RULES 0.01,
RCVD_IN_DNSWL_NONE -0.0001, RCVD_IN_MSPIKE_H3 -0.01,
RCVD_IN_MSPIKE_WL -0.01, SPF_PASS -0.001, URI_HEX 1.122, LANGUAGES en,
BAYES_USED global, SA_VERSION 3.4.0
X-Spam-source: IP=’209.85.214.52′, Host=’mail-it0-f52.google.com’, Country=’US’,
X-Spam-charsets: plain=’us-ascii’, html=’utf-8′
by compute1.internal (LMTPProxy); Tue, 19 Jun 2018 15:43:53 -0400
by mailmx.nyi.internal (Postfix) with ESMTP id BC118C86CB
for; Tue, 19 Jun 2018 15:43:52 -0400 (EDT)
id 30DAC181C53;
1529437432; b=Hs5q8xAiLNfAHCuMjmFUiHe2o2DPgHAQ3DxjImw1LSLUTpGkNW
2t86IEYMwZr5V/60yhitfTI1VhDEKKNsMonjkXOPLP5wHXnFDZpBaDHA+FNPNlzV
yNcs4S9EQ+8mXoegNZSg7cEGmusujol27yLCFlE+4KwJuKO5IduHOYo7meQbB/eh
OMfOZ9vOZeUf5/S7JQTARB8b7TefY/fUv7DlNXc+AHOr39zKwUgb5uvqKyWsg61P
GUuxojrU75K9JkhK2TzPnWZdH1ZweRU2/BeBgO7C0fAzsjm1s4S7sTi4HTEsMEH4
aujhkK2oeUaIFqCWt+MRx5uvbVvpthUTA8WQ==
messagingengine.com; h=from:content-type
:content-transfer-encoding:mime-version:date:subject:message-id
:references:in-reply-to:to; s=fm3; t=1529437432; bh=2r47bexiWx1n
zRXLloXjxgjGHPrJtPXdi6KXfQBpRyA=; b=K6b4nJCijfuX1MKwPFqvZKn699k4
q53KG3cHQZuW/erxmKOMz2RlkuM22nNqRguGzwbAnDEA4RdPWwWrAT4qXiqP1qoc
byvgQmvGbHDmYNXLGseIYiwjRpUFliyTIFsEVUIjS/JHHUqGgll/Sy03SSQ6WBhQ
R81qPfnFiV3Dqz6Pz5U/pI7o6EdCZkaKmj9LYv9/UwKtw3Kqa2UU1C45GKH5ftvs
UE5Bi09dry76eEHj0OccB20oNut1c5+KazWdumANxidebu6r2Zkv3GE2OjefQ1QU
ijiTBFJzRrvKNzr9WpLcLDW3yNEoz9ZP85tsgnKyszUxB2nHCyCTMIpEzw==
ARC-Authentication-Results: i=1; mx4.messagingengine.com; arc=none (no signatures found);
[email protected] header.b=nYKacmEE header.a=rsa-sha256
dmarc=pass (p=none,sp=quarantine,d=none) header.from=gmail.com;
iprev=pass policy.iprev=209.85.214.52 (mail-it0-f52.google.com);
spf=pass [email protected]
smtp.helo=mail-it0-f52.google.com;
x-cm=none score=0;
[email protected] header.b=eDEpokn8;
x-ptr=pass smtp.helo=mail-it0-f52.google.com
policy.ptr=mail-it0-f52.google.com;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
x-vs=clean score=0 state=0
x-cm=none score=0;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
X-ME-VSCategory: clean
X-CM-Envelope: MS4wfNBndLMZN7DGLOeAlcEzoJQ7Aw5A++1D4IKZLU81DEu7uUv032wHqR54hbeCkAy01Eroeddignf3dLkVRVwQbTrmnCxp16oCi2VPVlvi/kZioq4IWueK
hh0zMQuwPQ8ycwttYEw0U5kdAYgMX9Z73+9pxVBSzpRMWt6RJdEarXzA9iktnADQxQYBzANbTTwBFPx3rhg73sjfvRqE/kN6v9FlG6giHyL8tvwA5d2ra59D
X-CM-Analysis: v=2.3 cv=Ls28NEVc c=1 sm=1 tr=0 a=FiysPuC7j0KWWPdSEIJ08g==:117
a=B3oEefHhFTcVlgahaZg/xQ==:17 a=x7bEGLp0ZPQA:10 a=po3G2Dre0K0A:10
a=7mUfYlMuFuIA:10 a=9I5xiGouAAAA:8 a=OUyWigE-sChnsJ-678QA:9 a=CjuIK1q_8ugA:10
a=lg4JEFhukzMA:10 a=Cc_MeekYKk0A:10 a=7ROToYf0qM204g9Z:21 a=_W_S_7VecoQA:10
a=QEXdDO2ut3YA:10 a=ARFN2YZ7Uv8kHtb7LS-q:22
X-ME-CMScore: 0
X-ME-CMCategory: none
Received-SPF: pass
identity=mailfrom;
client-ip=209.85.214.52
Received: from mail-it0-f52.google.com (mail-it0-f52.google.com [209.85.214.52])
Received: by mail-it0-f52.google.com with SMTP id a3-v6so2161736itd.0
for; Tue, 19 Jun 2018 12:43:52 -0700 (PDT)
d=gmail.com; s=20161025;
h=from:content-transfer-encoding:mime-version:date:subject:message-id
bh=2r47bexiWx1nzRXLloXjxgjGHPrJtPXdi6KXfQBpRyA=;
b=nYKacmEEHbYWZP9N6yrqrN0H8QRnR/FHr1nwWWYaM/+eM2ARlFJ/xp2TuQLMrgeAcK
MrZlatCTAfriAUm92pFnMA0jcdv6jn9iscqGzVL8qQkcjo7M0oKgZiUCPmJ04qMUptNy
7gleU9ItogoYOwit19myBUiqjTUVBV46wiN7aOiC/yKrzPhzmhx7W1+ZPNk42zc3tPYE
EmBEGSum4A6b92gLpXjDhMSmHAFFT+bl0OPNClUif7rftoMB+D/1maNSHlCr4+/US2wk
kyTbI3pSltu0o4+ToCn0YltOIWwFDMYMoiFQwvfnw5pzBsabBPjgavcLJ7/VdknXH0H7
j4AQ==
d=1e100.net; s=20161025;
h=x-gm-message-state:from:content-transfer-encoding:mime-version:date
:subject:message-id:references:in-reply-to:to;
b=eDEpokn84J98AidlxZeQT1tuh4ogc7nzeHxlhgZVXYYLE/bmFOj22hOAPaP4L6VC6C
f4YExUL2AX6hhc7hvo5VaTfFlJ6/qBkf2PQen6SRVcE4g+BuC/MsWqOSsPDUBqyQsDkc
1WvPIG+vrMHdqU09u9x4tOlG7VBX3FoyMuYaoJmYL33Uq3bLmTLQIsHufjriJqf0BUA6
inkR8QErJ2XYS7KmO29gtAPJ3bpuSaVv4ZtDSTVDsWMkyDGYv620+UaSQiAeH/ldPXqy
WIoAq2DrPGczJ+Drs4a6JHevAwo+jQRY3EkJ2MmfhXvgDMC69xoTmSMuy1L5IQMTlCuJ
ZVXQ==
X-Gm-Message-State: APt69E2ILG5bWGO5+Gu1EUsdiZoaAh1t0LaMPPKiDQ3p5FCvqc3siWz9
RuPe8yNZ++izTx9J1PqCXFfYceUl
X-Google-Smtp-Source: ADUXVKLCT/mj/DKSp6pKt56g2EMjo48SDaFkKanKk8Ie5RbBgzeZuYOtlwavixV1tqjK/RBGjCpkzA==
X-Received: by 2002:a24:f04e:: with SMTP id p14-v6mr14203231iti.106.1529437430322;
Tue, 19 Jun 2018 12:43:50 -0700 (PDT)
Received: from [100.91.9.168] (mad5036d0.tmodns.net. [208.54.80.173])
by smtp.gmail.com with ESMTPSA id f3-v6sm189041iob.49.2018.06.19.12.43.49
for
(version=TLS1_2 cipher=ECDHE-RSA-AES128-GCM-SHA256 bits=128/128);
Tue, 19 Jun 2018 12:43:49 -0700 (PDT)
boundary=Apple-Mail-0D8518DA-C0FB-4B1A-AF48-C08B25D6A084
Mime-Version: 1.0 (1.0)
Date: Tue, 19 Jun 2018 20:43:47 +0100
Subject: Re: OUtput_Nodeoutput only read out the first plan file in the loop
To: “Ski907 [via HEC-RAS Help]”
X-Mailer: iPhone Mail (15F79)–Apple-Mail-0D8518DA-C0FB-4B1A-AF48-C08B25D6A084
Content-Type: text/plain;
charset=us-ascii
Content-Transfer-Encoding: quoted-printableThanks for posting!
Sent from my iPhone
> On Jun 19, 2018, at 1:41 AM, Ski907 [via HEC-RAS Help]
wrote:
>=20
> I came across this question while searching for a solution to my own probl=
em. I was having trouble looping through already computed plans changing the=
m with .PlanOutput_SetCurrent and .Plan_SetCurrent then extracting results u=
sing .Output_NodesOutput . It just seemed like the output file was not being=
updated. The solution was to change the plan, save it, close the project an=
d then re-open it:=20
>=20
> RC.Plan_SetCurrent (strPlanNames(j))=20
> RC.Project_Save=20
> RC.Project_Close=20
> RC.Project_Open strRASProject =20
>=20
>=20
> Hopefully this will save someone the time it took me to figure this out…=
=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/OUtput-Nodeoutput-only-read-out-=
the-first-plan-file-in-the-loop-tp3151p5781.html
> To start a new topic under HECRAS Controller, email ml+s1091112n1184h88@n5=
.nabble.com=20
> To unsubscribe from HECRAS Controller, click here.
> NAML–Apple-Mail-0D8518DA-C0FB-4B1A-AF48-C08B25D6A084
Thanks for posting!
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: 7bitSent from my iPhoneOn Jun 19, 2018, at 1:41 AM, Ski907 [via HEC-RAS Help] <[email protected]> wrote:I came across this question while searching for a solution to my own problem. I was having trouble looping through already computed plans changing them with .PlanOutput_SetCurrent and .Plan_SetCurrent then extracting results using .Output_NodesOutput . It just seemed like the output file was not being updated. The solution was to change the plan, save it, close the project and then re-open it:
RC.Project_Save
RC.Project_Close
If you reply to this email, your message will be added to the discussion below:To start a new topic under HECRAS Controller, email [email protected]
NAML
–Apple-Mail-0D8518DA-C0FB-4B1A-AF48-C08B25D6A084–July 25, 2018 at 3:59 am #13518AnonymousGuestThanks Ski901! I just ran into this issue with version 5.0.4 of the RAS Controller and your method to save and re-open worked.
