Welcome to the RAS Solution › Forums › HEC-RAS Help › output Htab Parameter table
  • #7521
    Charles Wu
    I am wondering if there is any way to export the Htab parameter table into an txt file or even Excel file? So I can display the cross-section table properties independently to someone who does not have HEC-RAS.
    Thank you!
    #12604
    You can display each cross section properties as a table and copy and paste them by hand one at a time to excel.
    I don’t know of automatic export in RAS. It might be possible to use the RAS controller to automate the export. I haven’t used this option. I imagine you could also get the results out of the hdf file. That is a bit complicated.
    #12605
    Charles Wu
    Thank you, but if fact I meant to export the Htab Parameter in once, I ended up pasting a figure into PDF file, thanks you for your reply still!
