Welcome to the RAS Solution › Forums › HEC-RAS Help › Operation rule for gate monthly releases water flow
- This topic has 1 reply, 208 voices, and was last updated 10 years, 1 month ago by Anonymous.
January 25, 2016 at 10:43 am #5977AnonymousGuest
Dear friends,
I want to set the operational rule in my simulation. I have monthly data of flow released from the reservoir through the gate of inline structure (dam). I can successfully simulated by using the Time Series Gate Opening (T.S. Gate Opening) for internal boundary condition of this inline structure. But the monthly flow through T.S. Gate Opening did not match with the real monthly flow out data through the gate. I try to set the Rules of this operation but it did not work. So, anyone please tell me how to create Rule for this operation?
The example of monthly data flow out through the gate:January 2013 -> 16cms
February 2013 -> 14cms
March 2013 -> 13cms
April 2013 -> 12cms
May 2013 -> 12cms
June 2013 -> 32cms
July 2013 -> 38cms
August 2013 -> 38cms
….Thanks,
January 25, 2016 at 1:23 pm #9633AnonymousGuestOh, I can do it now.
Using expression:
Rule Operation=Type=2,Var Name=HourBeg,Var Type=1,Existing Var=Year,Sim Group=Time,Sim Function=Hour of Simulation,Time=1
Rule Operation=Type=4,Var Type=1,Branch Type=0,Branch Or=0,BranchCompare1=5,BranchCompare2=0
Rule Expression=,Variable=HourBeg
Rule Expression=,Constant=0
Rule Operation=Type=3,Var Type=1,Gate=Gate #1,Sim Group=Inline Structures,Sim Function=Gate.Flow (Fixed)
Rule Expression=,Constant=29.79
Rule Operation=Type=4,Var Type=1,Branch Type=3,Branch Or=0,BranchCompare1=3,BranchCompare2=2
Rule Expression=,Constant=744
Rule Expression=,Constant=16.87
Rule Expression=,Constant=1440
Rule Expression=,Constant=14.08
Rule Expression=,Constant=2112
Rule Expression=,Constant=13
Rule Expression=,Constant=2856
Rule Expression=,Constant=12.48
Rule Expression=,Constant=3576
Rule Expression=,Constant=12.45
Rule Expression=,Constant=4320
Rule Expression=,Constant=32.91
Rule Expression=,Constant=7992
Rule Expression=,Constant=38
Rule Expression=,Constant=8712
Rule Expression=,Constant=24.95
Rule Expression=,Constant=9456
Rule Expression=,Constant=14.7
Rule Expression=,Constant=10200
Rule Expression=,Constant=13.69
Rule Expression=,Constant=10872
Rule Expression=,Constant=12.77
Rule Expression=,Constant=11616
Rule Expression=,Constant=12.37
Rule Expression=,Constant=12336
Rule Expression=,Constant=12.51
Rule Expression=,Constant=13080
Rule Expression=,Constant=17.5
Rule Expression=,Constant=16752
Rule Expression=,Constant=17472
Rule Expression=,Constant=28.62
Rule Operation=Type=4,Var Type=1,Branch Type=5,Branch Or=0,BranchCompare1=0,BranchCompare2=0 -
