Welcome to the RAS Solution Forums HEC-RAS Help On-Line Storage Area
  • #5516
    I am trying to model a connection between two lakes. I have an idealised short reach routing a flow hydrograph into the top lake, which is modelled as a storage area. Then I have the top and bottom lakes connected by a weir and culvert.
    My problem seems to be the connection between the short reach and the top lake. No flow is passing the last cross-section and is instead backing up.
    Any ideas what the issue may be?
    Regards,
    Ger
    #8802
    Keymaster
    Make sure that the reach is indeed connected to the storage area. This may assist you:
    http://hecrasmodel.blogspot.com/2010/08/how-to-use-storage-area-to-define.html
    This post discusses connection of a reservoir to a reach, but the way to connect the reach to a storage area is the same. You have to “move” the last vertex of the reach line into the storage area for RAS to recognize the connection.
