In the post about weirs in HEC-RAS, it was confirmed from the guys at HEC-RAS that in 2D-modelling weir uses to water surface elevation to calculate discharge over a weir.
When this is the case, and that flow over weirs in 1D is calculated using energy head, how:
1) Could we compare the two methods to each other?
2) Do we chose the discharge coefficient in 2D (considering the most used coefficients are derived using energy head as input).
BR
Sondre
