Welcome to the RAS Solution › Forums › HECRAS Controller › Obtain array of Station/Elevation for a cross section in RAS Controller
- This topic has 4 replies, 541 voices, and was last updated 7 years, 10 months ago by Anonymous.
May 23, 2018 at 9:15 am #8216AnonymousGuest
Hi Chris,
I am looking for a method obtaining any array or string of Station values and their corresponding ground elevation for a give cross-section (of a river/reach).
I searched in the user guide of Automating HEC-RAS but could not get.Alternatively, I tried parsing the *.g01 (Geometry file) but it can complicate things when we have 10 km long cross-sections.
I would like to know if there is any method (or can be built) in using RAS controller methods.
Anand KMay 23, 2018 at 6:02 pm #13589Chris G.KeymasterReturn-Path:
by sloti1d2t14 (Cyrus 3.1.3-613-gc72981f-fastmail) with LMTPA;
Wed, 23 May 2018 10:02:50 -0400
X-Cyrus-Session-Id: sloti1d2t14-3011811-1527084170-2-11151381107641156784
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-score: 0.0
X-Spam-hits: BAYES_00 -1.9, FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001,
RCVD_IN_DNSWL_NONE -0.0001, RCVD_IN_MSPIKE_H3 -0.01,
RCVD_IN_MSPIKE_WL -0.01, SPF_PASS -0.001, URI_HEX 1.122, LANGUAGES en,
BAYES_USED global_overload, SA_VERSION 3.4.0
X-Spam-source: IP=’74.125.82.180′, Host=’mail-ot0-f180.google.com’, Country=’US’,
X-Spam-charsets: plain=’us-ascii’, html=’utf-8′
Received: from mx3 ([10.202.2.202])
by compute1.internal (LMTPProxy); Wed, 23 May 2018 10:02:50 -0400
Received: from mx3.messagingengine.com (localhost [127.0.0.1])
by mailmx.nyi.internal (Postfix) with ESMTP id CBEB44613B
for; Wed, 23 May 2018 10:02:49 -0400 (EDT)
by mx3.messagingengine.com (Authentication Milter) with ESMTP
id F07031FFD28;
1527084169; b=eIz0mbJDwYAyBs2j90ZyFwGr1eLFZ0p4EkmooTWvHMASNP9HIg
orzoBTTkFaSmQ06YUUhMsPxsquNIoPNrfBtCQTIVMPu9vLBfd8p/cqix91T/gf6R
eruA/JkqzhK8g+9c6GzafaiWcZZKpQFMGyznpvn/GEyGSw7nLjHeg+aG+YxPnBjj
+PIt+AKdx37dEORC5vDDjb4v1zJWTR7ynjB896PEN51OhvMMrdgcF/mOK78zAE39
nUefSeU1uTupWG2lOoDQVHq7YTDkMofiNvo0vK+gc0jRh331PwoRbyJOsZuRND82
sTENaBjL91LnOsY23PpAt3OZxonlaBsD9Uvg==
messagingengine.com; h=from:content-type
:content-transfer-encoding:mime-version:date:subject:message-id
:references:in-reply-to:to; s=fm2; t=1527084169; bh=AiRRL0S7VBKR
EpwxrsKUgKvE8mCIUGPZR9X7OaJ/g1s=; b=LuhlGwefYfoW9i7aji+w8yEj9K24
xc2TaWRprYy2Z2UyyuuXKxn1kUy7On84QNYks7A4SBrjxCf1ZsLpf5hP/j7l2QUj
GUa3IuJ06/cs6Jga4djFw7CfusP2kwYKupAb/ocVrXL+9XPVFMbAZq3SAi/KdiyR
GS9I3JbNdiecBDS+Q+Z0b/LGVBQdTYZ4eByXC+gDFJYgFIgn/SB78ppiPnOt9y2m
t8l1BO4GovRqOPslgVwVIBUN9KC4rDWDDAB9vNjH8sUGN9pV/uKJ6WIYUpBDsxAW
KxGf4f+hYsbebFL54KTSYoAHywzneOHhlotlksGauiCpdO/ZimsaUmXSwg==
ARC-Authentication-Results: i=1; mx3.messagingengine.com; arc=none (no signatures found);
[email protected] header.b=EAsKirXh x-bits=2048 x-keytype=rsa
x-algorithm=sha256 x-selector=20161025;
dmarc=pass (p=none,d=none) header.from=gmail.com;
iprev=pass policy.iprev=74.125.82.180 (mail-ot0-f180.google.com);
spf=pass [email protected]
smtp.helo=mail-ot0-f180.google.com;
x-cm=none score=0;
[email protected] header.b=SsGbf6hi;
x-ptr=pass x-ptr-helo=mail-ot0-f180.google.com
x-ptr-lookup=mail-ot0-f180.google.com;
x-return-mx=pass smtp.domain=gmail.com smtp.result=pass
smtp_is_org_domain=yes header.domain=gmail.com header.result=pass
header_is_org_domain=yes;
x-tls=pass version=TLSv1.2 cipher=ECDHE-RSA-AES128-GCM-SHA256
bits=128/128;
x-vs=clean score=0 state=0
Authentication-Results: mx3.messagingengine.com;
x-cm=none score=0;
bits=128/128;
X-ME-VSCategory: clean
X-CM-Envelope: MS4wfFZ2mce3fHMWO3ZDxYVFN7dNDVGaCrUcJ99jNXBdvqX6KvXf26axuW/lKQg1drRGwklXiCMo7vKDIQGfJlAujlY1apWx66q+TCqb1VN1YFR08eQIhwFK
9CMDe2eF/fvBi6L9Ua73RAqu51OEJiFREDbGFLDYmKSY0o4A6G12jD/Y4mdSY9pIGSPAsdmHwyLKfN9bysSvUq+yLfHwnmmqm+AZgy/SZHdnkxisiyJcRoQy
X-CM-Analysis: v=2.3 cv=Tq3Iegfh c=1 sm=1 tr=0 a=n1rw/PkT84WRM9ouvbmWDg==:117
a=x7bEGLp0ZPQA:10 a=po3G2Dre0K0A:10 a=xqWC_Br6kY4A:10 a=4_-BN3WEXhEA:10
a=VUJBJC2UJ8kA:10 a=9I5xiGouAAAA:8 a=XhIHRxTSgjuO5fjFPuwA:9 a=CjuIK1q_8ugA:10
a=lg4JEFhukzMA:10 a=oDNnbiFrkEAA:10 a=zCR6bkHU8wMpuEBengMA:9
a=L2FrC6hrkbKzbLGn:21 a=_W_S_7VecoQA:10 a=QEXdDO2ut3YA:10
a=ARFN2YZ7Uv8kHtb7LS-q:22
X-ME-CMScore: 0
X-ME-CMCategory: none
Received-SPF: pass
receiver=mx3.messagingengine.com;
identity=mailfrom;
client-ip=74.125.82.180
Received: from mail-ot0-f180.google.com (mail-ot0-f180.google.com [74.125.82.180])
by mx3.messagingengine.com (Postfix) with ESMTPS
Received: by mail-ot0-f180.google.com with SMTP id 77-v6so25324415otd.4
for; Wed, 23 May 2018 07:02:49 -0700 (PDT)
d=gmail.com; s=20161025;
h=from:content-transfer-encoding:mime-version:date:subject:message-id
bh=AiRRL0S7VBKREpwxrsKUgKvE8mCIUGPZR9X7OaJ/g1s=;
b=EAsKirXhjcFay/zmONS/W3+cyuSUDVpGUffQiKwgKkaBhyLAXs45hO9apK4ynHSWfY
1J0MCBp6qurL4cTYPOoBjThWboBwiBMKjEdkmL01eoeKI70TnD5/ZhcWSVSywgHk39Bo
b/2F1+r9L5Hl5SpGD/RFfYaZEpjEKFOfEGL0k2V5NFLLRXr8rzy1kZdZnDPR9a/HSs0W
D56daWJlX3Cx5C1nsbfFDPUPMRz+wgTCYLtGfL/gIWUc4tyQGMJ8BNy9qScGEzHVKBSg
RTMq1xcg8mLTwxPDkRPE4BhJzOrAF1OcWqXIKuFhzt/k0irIiNHVUCFEN0MVIQp7YYTL
9MXw==
d=1e100.net; s=20161025;
h=x-gm-message-state:from:content-transfer-encoding:mime-version:date
:subject:message-id:references:in-reply-to:to;
b=SsGbf6hiFCw4G/fKQsJ/bXILr9IGHsOPyFsWnCxOna/LNWkaUw7GtJCM/y/pCHPVNL
NZaZDTWgSJL9THgyd3kHHegmgVAYEEk7N+kawkOtITGOa2+5fjVJ+qgL3iFzLoR4/oZ1
lUtjJNRCbHlm9vDOhs/hJWdtDA6LmQHXusgVRG65EC2dfeYrlRutSIfH7gLu14Sg2Ryu
o0mxHyb75h4QF6rAv9cXawvZ5vhXje71Dlg9YWQI1LJcq/zWWXq1Myx0ZjJr8XuN6j4g
4CzEPB17qpBmEAUiW5Jc78/H1W3Z/ZDIKdcxiJmOThfxmevHRarINkT7uHVeI8mrblXX
Ph6g==
X-Gm-Message-State: ALKqPwepSOifQGUFwfwpvQgODedJpaSbt8TCd8qWamlKFtbhtW6VrttA
gt2fDez6n8UbeIjWTYGsmPzBGDY0
X-Google-Smtp-Source: AB8JxZrab8jMRvTy7orjiE63wKkaVx7hPLouCIGobTLAhSAA4aztV5Ip260VdZzMiGJvWGrc32fkVg==
X-Received: by 2002:a9d:250c:: with SMTP id k12-v6mr1912686otb.362.1527084167300;
Wed, 23 May 2018 07:02:47 -0700 (PDT)
Received: from ?IPv6:2607:fb90:5c46:4bfc:5dfb:d3b5:5d41:e079? ([2607:fb90:5c46:4bfc:5dfb:d3b5:5d41:e079])
by smtp.gmail.com with ESMTPSA id c2-v6sm10560468oia.15.2018.05.23.07.02.45
for
(version=TLS1_2 cipher=ECDHE-RSA-AES128-GCM-SHA256 bits=128/128);
Wed, 23 May 2018 07:02:46 -0700 (PDT)
boundary=Apple-Mail-33BC90A1-6E34-4FFF-A686-38F74F7B7E0E
Mime-Version: 1.0 (1.0)
Date: Wed, 23 May 2018 09:02:45 -0500
Subject: Re: Obtain array of Station/Elevation for a cross section in RAS Controller
Message-Id:
To: “Anand Kulkarni [via HEC-RAS Help]”
X-Mailer: iPhone Mail (15E302)–Apple-Mail-33BC90A1-6E34-4FFF-A686-38F74F7B7E0E
Content-Type: text/plain;
charset=us-ascii
Content-Transfer-Encoding: quoted-printableHi Amanda, Unfortunately, parsing the g01 file is the only way to do this.=20=
Sent from my iPhone
> On May 23, 2018, at 12:15 AM, Anand Kulkarni [via HEC-RAS Help]
wrote:
>=20
> Hi Chris,=20
> I am looking for a method obtaining any array or string of Station values a=
nd their corresponding ground elevation for a give cross-section (of a river=
/reach).=20
> I searched in the user guide of Automating HEC-RAS but could not get.=20
>=20
> Alternatively, I tried parsing the *.g01 (Geometry file) but it can compli=
cate things when we have 10 km long cross-sections.=20
>=20
> I would like to know if there is any method (or can be built) in using RAS=
controller methods.=20
>=20
> Thanks=20
> Anand K =20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/Obtain-array-of-Station-Elevatio=
n-for-a-cross-section-in-RAS-Controller-tp5655.html
> To start a new topic under HECRAS Controller, email ml+s1091112n1184h88@n5=
.nabble.com=20
> To unsubscribe from HECRAS Controller, click here.
> NAML–Apple-Mail-33BC90A1-6E34-4FFF-A686-38F74F7B7E0E
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: 7bitChrisSent from my iPhoneOn May 23, 2018, at 12:15 AM, Anand Kulkarni [via HEC-RAS Help] <[email protected]> wrote:Hi Chris,
Anand K
If you reply to this email, your message will be added to the discussion below:To start a new topic under HECRAS Controller, email [email protected]
NAML
–Apple-Mail-33BC90A1-6E34-4FFF-A686-38F74F7B7E0E–May 25, 2018 at 7:39 pm #13590TobyParticipantHi,
You can accomplish this by using the .g01.hdf or .p01.hdf file.
Here is an R script to get you started. This works in 5.0.3. You would need to update a line or two to get it to work in 5.0.4.
cheers,
# To access HDF5 files in R, we will use the rhdf5 library which is part of the
#Bioconductor suite of R libraries.#install rhdf5 package
#source(“http://bioconductor.org/biocLite.R”)
#biocLite(“rhdf5”)# load libraries
library(raster)
library(rhdf5)
library(rgdal)
library(sp)
library(maptools)
library(rgeos)# #####################################################################################################
# # Cross-section compairson
# # set working directory
# setwd(“C:\\Users\\yourComp\\Documents\\myRAS”)
# # define the file name as an object
# plan<-"model.g01.hdf" # # proj 4 string - look to http://www.spatialreference.org
# sp.Ref<- "+proj=lcc +lat_1=38.33333333333334 +lat_2=39.83333333333334 +lat_0=37.66666666666666 +lon_0=-122 # +x_0=2000000 +y_0=500000.0000000001 +datum=NAD83 +units=us-ft +no_defs +ellps=GRS80 +towgs84=0,0,0" # # ##################################################################################################### # # Use of function... # # ras.data<-RAS_XS_to_R(plan, SP.Ref=NULL) # # #Unpack xs data # xs_lines<-ras.data[[1]] # # #Unpack profile data # profile<-ras.data[[2]] # ##################################################################################################### #function RAS_XS_to_R<-function(plan, sp.Ref=NULL){ ##################################################################################################### #Extract xs metadata path<-"Geometry/Cross Sections/River Names" riverNames <- t(h5read(plan, path)) #trim trailing whitespace riverNames<-sub("\\s+$", "", riverNames) path<-"Geometry/Cross Sections/Reach Names" reachNames <- t(h5read(plan, path)) #trim trailing whitespace reachNames<-sub("\\s+$", "", reachNames) path<-"Geometry/Cross Sections/River Stations" riverStations <- t(h5read(plan, path)) #trim trailing whitespace riverStations<-sub("\\s+$", "", riverStations) path<-"Geometry/Cross Sections/Node Descriptions" nodeDesc <- t(h5read(plan, path)) #remove \r\n nodeDesc<-as.character(gsub("\r\n"," ",nodeDesc)) # create reach names xsNames<-paste0(riverNames," ",reachNames," ",riverStations) #find the River channel reach lengths path<-"Geometry/Cross Sections/Lengths" reachLengths <- t(h5read(plan, path)) ##################################################################################################### # Get geometry # get xs point count path<-"Geometry/Cross Sections/Polyline Parts" xs.parts <- h5read(plan, path) xs.parts.sum<-cumsum(xs.parts[2,]) # get xs coords path<-"Geometry/Cross Sections/Polyline Points" xs.points <- t(h5read(plan, path)) nrow(xs.points) ##################################################################################################### #Create XS lines tmp<-xs.points[1:xs.parts.sum[1],] xs_lines<-SpatialLines(list(Lines(list(Line(tmp)), ID = "1"))) for(i in 2:length(xs.parts.sum)){ tmp<-xs.points[(xs.parts.sum[i-1]+1):xs.parts.sum[i],] L.tmp <- SpatialLines(list(Lines(list(Line(tmp)), ID = as.character(i)))) xs_lines <- spRbind(xs_lines, L.tmp) }# close i loop #create the spatial lines xs_lines<-SpatialLinesDataFrame(xs_lines, data.frame(xsNames=xsNames,rivNames=t(riverNames),reaNames=t(reachNames), rivSta=t(riverStations),Desc=nodeDesc,ReachLen=reachLengths)) # Assign the sp ref if provided if(!is.null(sp.Ref)){ crs(xs_lines)<-sp.Ref } ##################################################################################################### # get cross section station and elevation data from RAS path<-"Geometry/Cross Sections/Station Elevation Info" eleInfo <- t(h5read(plan, path)) path<-"Geometry/Cross Sections/Station Elevation Values" eleValue <- t(h5read(plan, path)) # convert profile values to dataframe profile<-data.frame(station=eleValue[,1], elev=eleValue[,2]) # assign each profile an id profile$id<-NA for(i in 1:nrow(eleInfo)){ startID<-eleInfo[i,1] endID<-startID + eleInfo[i,2] profile$id[(startID+1):endID]<-i }#close i loop # give profile names ids xsNames<-data.frame(id=1:length(xsNames), names=xsNames) profile$xsName<-xsNames[match(profile$id,xsNames$id),"names"] # xs stationing may not start at zero!!! # correct for xs which do not start at 1 for(i in 1:length(unique(profile$id))){ index<-which(profile$id==i) if(profile[index,1][1]!=0){profile[index,1]<-profile[index,1]-profile[index,1][1]} }# close i loop return(list(xs_lines, profile)) }# close functionMay 27, 2018 at 7:20 pm #13591PaoloPParticipantHi Anand,
you can download from http://www.m3eweb.it/products/ the App RAS to Excel and than copy part of the program that gets stations/elevations from .gxx file.
PaoloP
June 5, 2018 at 6:12 pm #13592AnonymousGuestHi all,
Thanks for the reply that is encouraging. I will try out the methods.Regards,
Anand K -
