Welcome to the RAS Solution Forums HEC-RAS Help Obstructions with a Culvert
  • This topic has 1 reply, 451 voices, and was last updated 12 years ago by Anonymous.
  • #5299
    Im trying to model a culvert with an 18in sewer pipe running through it for a FEMA model. I was wondering what the best way to model this might be?
    The only thing I can think of is to add cross sections immediately up- and down-stream of the culvert and add the obstructions to those cross sections but I wasn’t sure if there was a better/more appropriate way of handling this.
    #8448
    jadams
    You could try adding culvert blockage that is equivalent the intersecting pipe as depth blocked.
