Welcome to the RAS Solution › Forums › HEC-RAS Help › Obstructions in 2D area
- This topic has 3 replies, 2,151 voices, and was last updated 10 years, 7 months ago by Anonymous.
August 10, 2015 at 2:11 pm #5851AnonymousGuest
Dear 2D HEC-RAS users,
I am running a dam break in a HEC-RAS model with only a 2D mesh. The dam is a small flood retention dam and only about 5 m (about 16 ft) tall. The storage volume is only 47’000 m3 (38 ac-ft). The breach affects only the local areas close to the small river (2m/6ft wide) and I need to model the houses in that area.
I have two GeoTIFF terrain models that I can work with. One is a DTM and the other a DSM with all trees and houses. I do however not want to model the trees as those distort the flow paths.
In the 1D cross sections it is possible to create obstructions to permenantly block out areas. I was wondering if it is possible to do something similar in 2D. Does anyone know if there is a way to block flow through certain areas? There are two many houses to lift the surface at each one of them, so I’m trying to find another way. Or should I try to lift the surface of the DTM in GIS and then import this into RAS Mapper?Thank you for your help
Regards,
StephanieAugust 11, 2015 at 1:14 am #9463Lonnie AParticipantYou can define a landuse layer and set the N=1 for the building footprint areas. I believe RAS takes the majority of the landuse in the cell as it’s n-value for that cell.
August 11, 2015 at 1:46 am #9464RobertParticipantHi Stephanie,
HecRas 5.0 (2D) hasn’t ability to define the obstacles by Obstructions. I hink, the best option is use dtm with buildings.
I think, that increase n-values isn’t well solution, Lonnie. Because you change only properties of flow, but the houses will be flooded.
regards
RobertAugust 11, 2015 at 5:08 am #9465Chris G.KeymasterReturn-Path:
Received: from mail-pd0-f171.google.com (mail-pd0-f171.google.com [209.85.192.171])
by mbob.nabble.com (Postfix) with ESMTP id 2287712E6BE5
for; Mon, 10 Aug 2015 17:07:53 -0700 (PDT)
Received: by pdrg1 with SMTP id g1so76711973pdr.2
for; Mon, 10 Aug 2015 17:08:17 -0700 (PDT)
d=gmail.com; s=20120113;
bh=HKBhe0JLBQbujXfWxiaincDWDJ+Njdd/AifLNKKePXo=;
b=jKYCIcbrJsw5XTXuMtsUDfXnU8FvpgfsREvOJfxdL6apCwn9NewZ2BsyF+DgYbqNxC
dLDBFKfZ7l5jW/HNSKYGTqxuc6KtSzOKh6DyiqwCFLJitx78Hw8sCRdMtbXStzq+F2x/
j3TLTletsj1JQ0nQfMWaKnM8T6EU9d5BYUwl8SVotCBkospVxI9LIPV7B7aLuRhBxRK2
rPwnPHugNSLZlo8J2A9/rgtoBI+5X7aIv8Ts0iB0upU5j3SCPXvq1k4V5+Mwrn51lSyb
UhkSDYo1ZudZha+mkUiDfridvZDZmW7MQcmoV3nZqUGmeKBmF1t0O42XdJPVu4r6Leub
/rng==
X-Received: by 10.70.90.161 with SMTP id bx1mr50328772pdb.10.1439251696931;
Mon, 10 Aug 2015 17:08:16 -0700 (PDT)
Received: from ?IPv6:2600:100f:b10c:2afc:92:8b3a:a873:385d? ([2600:100f:b10c:2afc:92:8b3a:a873:385d])
by smtp.gmail.com with ESMTPSA id ev2sm145299pbb.37.2015.08.10.17.08.14
for
Mon, 10 Aug 2015 17:08:15 -0700 (PDT)
Subject: Re: Obstructions in 2D area
boundary=Apple-Mail-9E56A239-6360-4510-A587-08326BBEE42C
X-Mailer: iPhone Mail (12D508)
Message-Id:
Date: Mon, 10 Aug 2015 17:08:11 -0700
To: “Stephanie Morach [via HEC-RAS Help]”
Mime-Version: 1.0 (1.0)–Apple-Mail-9E56A239-6360-4510-A587-08326BBEE42C
Content-Type: text/plain;
charset=us-ascii
Content-Transfer-Encoding: quoted-printableLifting the terrain is one option. But you could also use 2D area connection=
s to block flow. Another option is to draw n value areas around the building=
s to block and assign very high n values (say about 10). N values effectivel=
y block the flow but also account for the storage of water inside the buildi=
ngs.=20Sent from my iPhone
> On Aug 10, 2015, at 02:11, Stephanie Morach [via HEC-RAS Help]
wrote:
>=20
> Dear 2D HEC-RAS users,=20
>=20
> I am running a dam break in a HEC-RAS model with only a 2D mesh. The dam i=
s a small flood retention dam and only about 5 m (about 16 ft) tall. The sto=
rage volume is only 47’000 m3 (38 ac-ft). The breach affects only the local a=
reas close to the small river (2m/6ft wide) and I need to model the houses i=
n that area.=20
> I have two GeoTIFF terrain models that I can work with. One is a DTM and t=
he other a DSM with all trees and houses. I do however not want to model the=
trees as those distort the flow paths.=20
> In the 1D cross sections it is possible to create obstructions to permenan=
tly block out areas. I was wondering if it is possible to do something simil=
ar in 2D. Does anyone know if there is a way to block flow through certain a=
reas? There are two many houses to lift the surface at each one of them, so I=
‘m trying to find another way. Or should I try to lift the surface of the DT=
M in GIS and then import this into RAS Mapper?=20
>=20
> Thank you for your help=20
> Regards,=20
> Stephanie=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/Obstructions-in-2D-area-tp1896.h=
tml
> NAML–Apple-Mail-9E56A239-6360-4510-A587-08326BBEE42C
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: 7bitLifting the terrain is one option. But you could also use 2D area connections to block flow. Another option is to draw n value areas around the buildings to block and assign very high n values (say about 10). N values effectively block the flow but also account for the storage of water inside the buildings.Sent from my iPhone
On Aug 10, 2015, at 02:11, Stephanie Morach [via HEC-RAS Help] <[email protected]> wrote:Dear 2D HEC-RAS users,
Regards,
Stephanie
If you reply to this email, your message will be added to the discussion below:http://hec-ras-help.1091112.n5.nabble.com/Obstructions-in-2D-area-tp1896.html
NAML
–Apple-Mail-9E56A239-6360-4510-A587-08326BBEE42C– -
