Welcome to the RAS Solution Forums HEC-RAS Help not able to build simulation. Please Help
  • #5382
    mkvidyashankar
    Hi I am new to HEC RAC and I am trying to build flood inundation map for my office project.
    Not able to build simulation.
    I am attaching the debug file
    Help from members is highly appreciated.
    Thanks in advance
    vidyashankar
    urp_reverse.p06.zip
    #8624
    MichaelG
    Hi: I looked at your data and noted several problem areas; one being overlapping of a storage area with cross sections and another being cross sections spaced too closely for an unsteady flow simulation. You can find my notes at: https://files.secureserver.net/0st9XnfLcyi4BJ
    Regards,
    Michael
    #8625
    mkvidyashankar
    Return-path:
    Envelope-to: [email protected]
    Delivery-date: Tue, 08 Oct 2013 01:15:44 -0700
    Received: from mail-wg0-f44.google.com ([74.125.82.44])
    by sam.nabble.com with esmtp (Exim 4.72)
    (envelope-from )
    id 1VTSSE-0006jp-Lw
    for [email protected]; Tue, 08 Oct 2013 01:15:43 -0700
    Received: by mail-wg0-f44.google.com with SMTP id z12so317655wgg.23
    for ; Tue, 08 Oct 2013 01:15:36 -0700 (PDT)
    d=gmail.com; s=20120113;
    h=mime-version:in-reply-to:references:date:message-id:subject:from:to
    :content-type;
    bh=LfHAnIBEay2/puHMYNj7jNJyYMRqbgHJSs2HxMvJqy0=;
    b=fC2jXgXOVLk9xX8tjP4uSLv24c54Wa+6A593bl7IgoagrUHSlYfs4/OIJHwReFR9Oh
    KbWU2HTHgAIMY4602I3KGM+/vXSgwBDt1f2gMOt0N5OJBfHyEmCQ1FA1X2rPbUBKJ0Is
    2P/dL4kMx+Bf6BUZHMGzipdjCYaPZ6/2Rag6jvGDJvEiicnw57m4QhKyWO4t5LDnGgvg
    LPxInScpw23GrbwJ+hi8kA+cEW495RPY9SDzitqQCgotK828iJRJOYUeBebxiZw43R3j
    EaQLK8N+PUPuKlkx0um6KpSaBNnurFdP8GQbLk2mOCGjD4Z/2YQJMwrLUum0XoAsCJvR
    0HMw==
    MIME-Version: 1.0
    X-Received: by 10.180.89.206 with SMTP id bq14mr346110wib.56.1381220136526;
    Received: by 10.227.182.79 with HTTP; Tue, 8 Oct 2013 01:15:36 -0700 (PDT)
    <[email protected]>
    Date: Tue, 8 Oct 2013 13:45:36 +0530
    Message-ID:
    Subject: Re: not able to build simulation. Please Help
    To: “MichaelG [via HEC-RAS Bloggery Forum]”
    Content-Type: multipart/alternative; boundary=e89a8f3b9da9982a6c04e8365f3a
    X-SA-Exim-Connect-IP: 74.125.82.44
    X-SA-Exim-Mail-From: [email protected]
    X-SA-Exim-Scanned: No (on sam.nabble.com); SAEximRunCond expanded to false
    –e89a8f3b9da9982a6c04e8365f3a
    Content-Type: text/plain; charset=ISO-8859-1
    Hi Michael
    Got some idea about errors, I will try to correct this as per the guideline=
    Thank you for the valuable guidance
    Regards
    Vidyashankar
    On Tue, Oct 8, 2013 at 6:31 AM, MichaelG [via HEC-RAS Bloggery Forum] < [email protected]> wrote:
    > Regards,
    > Michael
    > below:
    > http://hec-ras-bloggery-forum.1091112.n5.nabble.com/not-able-to-build-sim=
    ulation-Please-Help-tp398p400.html
    > To unsubscribe from not able to build simulation. Please Help, click her=
    e<http://hec-ras-bloggery-forum.1091112.n5.nabble.com/template/NamlServlet.=
    jtp?macro=3Dunsubscribe_by_code&node=3D398&code=3DbWt2aWR5YXNoYW5rYXJAZ21ha=
    WwuY29tfDM5OHwtMTc4OTM4Nzc2NA=3D=3D>
    > NAML<http://hec-ras-bloggery-forum.1091112.n5.nabble.com/template/NamlSer=
    vlet.jtp?macro=3Dmacro_viewer&id=3Dinstant_html%21nabble%3Aemail.naml&base=
    =3Dnabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNam=
    espace-nabble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscrib=
    ers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant=
    _email%21nabble%3Aemail.naml>
    –=20
    Regards
    Vidyashankar
    Content-Type: text/html; charset=ISO-8859-1
    Hi Michael
    Got some idea about errors, =
    I will try to correct this as per the guideline.
    T=
    Regards
    Vidyashankar
    On Tue, Oct 8, 2013 at 6:31 AM, MichaelG [via =
    HEC-RAS Bloggery Forum] <[email protected]=
    bble.com
    wrote:
    x #ccc solid;padding-left:1ex">
    Hi: I looked at your data and noted several problem areas; one being overl=
    apping of a storage area with cross sections and another being cross sectio=
    ns spaced too closely for an unsteady flow simulation. You can find my note=
    s at: https://files.secureserver.net/0s=
    t9XnfLcyi4BJ
    Regards,
    Michael
    =09
    =09
    =09
    http://hec=
    -ras-bloggery-forum.1091112.n5.nabble.com/not-able-to-build-simulation-Plea=
    =09
    To unsubscribe from not able to build simulation. Please Help, click here.
    NAML
    Regards
    =A0
    Vidyashankar
    –e89a8f3b9da9982a6c04e8365f3a–
