Welcome to the RAS Solution › Forums › HEC-RAS Help › No data for plot
- This topic has 1 reply, 135 voices, and was last updated 6 years, 2 months ago by Ojo shakirah.
January 17, 2020 at 10:09 pm #7584Ojo shakirahParticipant
Return-Path:
by sloti1d2t14 (Cyrus 3.1.7-754-g09d1619-fmstable-20200113v1) with LMTPA;
Fri, 17 Jan 2020 13:09:22 -0500
X-Cyrus-Session-Id: sloti1d2t14-1579284562-4071395-2-13261252724390795717
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-sender-reputation: 500 (none)
X-Spam-score: 0.2
X-Spam-hits: FREEMAIL_ENVFROM_END_DIGIT 0.25, FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001,
ME_SENDERREP_NEUTRAL 0.001, RCVD_IN_DNSWL_NONE -0.0001,
RCVD_IN_MSPIKE_H2 -0.001, SPF_HELO_NONE 0.001, SPF_PASS -0.001,
LANGUAGES en, BAYES_USED none, SA_VERSION 3.4.2
X-Spam-source: IP=’209.85.166.178′, Host=’mail-il1-f178.google.com’, Country=’US’,
Received: from mx3 ([10.202.2.202])
by compute1.internal (LMTPProxy); Fri, 17 Jan 2020 13:09:22 -0500
Received: from mx3.messagingengine.com (localhost [127.0.0.1])
by mailmx.nyi.internal (Postfix) with ESMTP id 7732A20093
for; Fri, 17 Jan 2020 13:09:20 -0500 (EST)
by mx3.messagingengine.com (Authentication Milter) with ESMTP
id D038B32E2B8;
ARC-Seal: i=1; a=rsa-sha256; cv=none; d=messagingengine.com; s=fm1; t=
1579284560; b=wQoA0dFTTj6IS2uI7Py9cGrx0b78KVCFAui1j8a5JdDVSq5KGw
UFZHPzYT6t0jyv862qpNc2po128/bQcimyFFamnATNt7BhwVEontywRVM0STAQHd
k9swEUamrKjaB0IaP82s+WZnKXXCsBkaDOzAef+a/Uinl5dsu+OYuiWE7e8eOS1P
jpV7CSFUMiTc4r5m6kLN60zIJa6q/5RQZppuKV56EHBCLgy3fTxYWKrDpGcMESKY
bKuskbOwMhdozV3IWl/ZgfSXUbCTJFEAXEFjmhimasXgKE1UQ/ALjP6s4ee8eepK
k3SKRJkd0r3Sft4n/2hI82/eCk1sDbz5/5kw==
messagingengine.com; h=mime-version:from:date:message-id:subject
:to:content-type; s=fm1; t=1579284560; bh=q91qDpmzINzcuBeaLXhPlr
krsDaQe+8iQG8hhg6xtdY=; b=ySrWcig1MKLpIBHbv4HMmR59SIPZmZnHc/Uann
9wwq+v9iA/mEncP6h89JSVmM3jm/wj23CgCAxvWaWxcJPlf0wfSkQEAE+ZRdMnxH
3ezvOcfkeNdcaFbMZhnHSMZQoB8J7tYqlmsu5tH/L74SPpkmoisRtGKdDqkfLTy9
5c/u6GG24UDmeYZEBo7VeW8LsC3blleWl9S1q+i/cws6iJDNy1aUmxrQwqs4ibut
iEtM6xrvxjw+XdaXMnc83FzkJS90iWkf2WiRgV4TYFhWnk/U0GGKO+eqH+DvFhOm
qu87D7vSDbk4gACHg6eYHe7NxFRx+wPthfeXq1/BqM4+Ifmg==
ARC-Authentication-Results: i=1; mx3.messagingengine.com; arc=none (no signatures found);
bimi=none (Domain is not BIMI enabled);
[email protected] header.b=hamxCZuS header.a=rsa-sha256
header.from=gmail.com;
iprev=pass smtp.remote-ip=209.85.166.178 (mail-il1-f178.google.com);
spf=pass [email protected]
smtp.helo=mail-il1-f178.google.com;
[email protected] header.b=ZsS5AZtd;
x-ptr=pass smtp.helo=mail-il1-f178.google.com
policy.ptr=mail-il1-f178.google.com;
(MX Records found: alt2.gmail-smtp-in.l.google.com,alt4.gmail-smtp-in.l.google.com,gmail-smtp-in.l.google.com,alt3.gmail-smtp-in.l.google.com,alt1.gmail-smtp-in.l.google.com);
smtp.bits=128/128;
x-vs=clean score=0 state=0
Authentication-Results: mx3.messagingengine.com;
smtp.bits=128/128;
X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgedugedrtdekgddugecutefuodetggdotefrodftvf
curfhrohhfihhlvgemucfhrghsthforghilhdpggftfghnshhusghstghrihgsvgdpuffr
tefokffrpgfnqfghnecuuegrihhlohhuthemuceftddtnecunecujfgurhepggfhfffkuf
fvtgesrgdtreertddtjeenucfhrhhomhepqfhjohcutfhomhhokhgvucfuhhgrkhhirhgr
thcuoehomhhougholhgrphhotdelieesghhmrghilhdrtghomheqnecukfhppedvtdelrd
ekhedrudeiiedrudejkeenucfrrghrrghmpehinhgvthepvddtledrkeehrdduieeirddu
jeekpdhhvghlohepmhgrihhlqdhilhduqdhfudejkedrghhoohhglhgvrdgtohhmpdhmrg
hilhhfrhhomhepoehomhhougholhgrphhotdelieesghhmrghilhdrtghomhequcfukfgk
gfepvdeiieelnecuvehluhhsthgvrhfuihiivgeptd
X-ME-VSScore: 0
X-ME-VSCategory: clean
Received-SPF: pass
receiver=mx3.messagingengine.com;
identity=mailfrom;
client-ip=209.85.166.178
Received: from mail-il1-f178.google.com (mail-il1-f178.google.com [209.85.166.178])
by mx3.messagingengine.com (Postfix) with ESMTPS
for; Fri, 17 Jan 2020 13:09:19 -0500 (EST)
Received: by mail-il1-f178.google.com with SMTP id b15so22019647iln.3
for; Fri, 17 Jan 2020 10:09:19 -0800 (PST)
d=gmail.com; s=20161025;
h=mime-version:from:date:message-id:subject:to;
bh=q91qDpmzINzcuBeaLXhPlrkrsDaQe+8iQG8hhg6xtdY=;
b=hamxCZuSHuVE+Me/NthoIxMZSmw6vtu6cOPky+GUrZa5sy0xpa6Uu8cLs7G8xvbsat
nqRsNHg3rq2YbRjh7RLy7tyl+QoZ4ZNF/krTIs6NdgoxbtGAmMeHGkYSYhmGqPiS1m3x
hw/ZPHzE1yQeuHZJgi+/aXU7BZogFCJSZlRqRvOxNndcExLoXHkK3jsJGyYaD0Ij0gov
ZqNmz7dSrV6FEc4KHA6VcgVgNgQHXNg4u7Tzx6DpNthIFBh64uzXAqrusqwrd/jSsq4T
jimh/Y3ZQjLOr5TXWPwALSebwb4Td2U53El6Tu/C7M1r+ukoL480C9n0jaD0sGBAYUFe
MdmQ==
d=1e100.net; s=20161025;
h=x-gm-message-state:mime-version:from:date:message-id:subject:to;
b=ZsS5AZtdR+JQcEkc1554r1STu45fHU6MXpOAdhimeVFd+ZVxfJJ7KmvveZvi4OrfA3
181f560EZVaKMzHmHGNudB7H/+5mf+JB1Y/L8pljFmbUkS1tkUfosDEC7bbUq1jY5Y0E
UGMzyMl3jA7i910D89cY6K+jQ3xvaLQSP8L6ZA85FKY9CXeXGHUrEguVAIb8DDNXRz79
BbwMNfOxDje1Aths7hUt1A960PMJgOvDcIw/m1+TIX7AObgaoOup+vlRvc2HBduYl0jw
11KrQEH5qUfb9wMh0ctdpxdyixorsPe6EU5u1arkow9fYO33sLSjjRlCS4R0WXMryO2/
panA==
X-Gm-Message-State: APjAAAUQiGxYURGDEuRrrG8/Q9vjW0B+7xIpMTqTWWoqqEAAParJBkwI
g679QiV2RJvgZAngGPjax8pohr8dFwFVYDNCD2Ph0A==
X-Google-Smtp-Source: APXvYqwupZZ4eBynDCKgKAJBsytGs90FdiRZXVngfavSoQGG0SpV/ndR9Oc9ne5a2j3m0RGal5ah3Ui3lr8D9OSCcPo=
X-Received: by 2002:a92:8904:: with SMTP id n4mr3922610ild.88.1579284557421;
Fri, 17 Jan 2020 10:09:17 -0800 (PST)
MIME-Version: 1.0
Date: Fri, 17 Jan 2020 19:09:04 +0100
Message-ID:
Subject: No data for plot
To: [email protected]
Content-Type: multipart/alternative; boundary=”0000000000000b5ef1059c59d77e”–0000000000000b5ef1059c59d77e
Content-Type: text/plain; charset=”UTF-8″Pls I need help, when I import my geometric data into hecras there is no
value under the station and elevation column, as a result there is no data
to check my the profile–0000000000000b5ef1059c59d77e
Content-Type: text/html; charset=”UTF-8″Pls I need help, when I import my geometric data into hecras there is no value under the station and elevation column, as a result there is no data to check my the profile–0000000000000b5ef1059c59d77e–
February 6, 2020 at 4:29 am #12700cameronParticipantwhere are you importing your data from?
