Hi there,
I am receiving the errors
“AmiteRiver Abv_ComiteR 552649.4
THIS IS USUALLY CAUSED BY BAD STATION/ELEVATION DATA
IF THIS NODE HAS A WEIR (BRIDGE etc.) CHECK THE ROAD DECK DATA CAREFULLY
–PROGRAM ABORTED–
Image PC Routine Line Source
NEGATIVE AREA IN SUBROUTINE CONVEY
BETWEEN STATION 6305.06 AND 6663.67
RasSteady64.exe 00007FF7FB7E6795 Unknown Unknown Unknown
–PROGRAM ABORTED–”
and then
“Error with program: RasSteady64.exe Exit Code = 157”
I checked the bridge data and everything seems to be in order. What I find curious is that I have run this bridge data before and have not gotten these errors causing the run to stop. I have updated the river centerlines and banklines to different conditions and I wonder if this could have an impact? I did not change the bridge or bounding cross sections at all, however, the channel invert elevations along the channel did change and are not as smooth as the previous conditions. Could changing the other cross sections impact the bridge? I did update the htab parameters before running. I also tried computing the property table in RAS mapper before running, but this did not solve the problem.
Something else that confused me was that the errors were citing station points that don’t appear to be points in my bridge data cross section. Is that normal?
Thanks in advance for any guidance!
